Intel® Makers
9872 Discussions
Sketches do not run on arduino 101 clone with C1000 omitting BLE etc.
RMoll1
I did the following:
I made a propriatary PCB layout copying the arduino 101 schematic and omitting the periperals (as BLE) of the Curie Module.
Due to the fact that there is no exact schematic of the Curie Module I guessed the wireing from the C1000 development platform.
I uploaded an arduino 101 bootloader via JTAG interface into the C1000-board.
As a result the board is recognized by the Arduino IDE (1.8) , both Windows drivers are loaded , I can fetch the serial number of the board via the USB/COM port and I can upload sketches without error messages.
Unfortunately the sketches do not run. Even a simple blinky-sketch does not work.
Does the code check for the presence of the bluetooth chip or other peripherals and hangs, if no response is received?
I would appreciate to get your ideas on this.
Thanks in advance.
Community Manager
Hello ruedi,
Please post your question on Embedded Community and an Intel dedicated team will assist you.
Link here: https://embedded.communities.intel.com/select-display-name!input.jspa?reg=1
Thank you and best regards,
Eliza
