Community
cancel
Showing results for
Search instead for
Did you mean:
IZ1
SoftAP programming API
Jump to solution
Not sure if this should be posted on Software or Hardware/Firmware sub forum. I went through Intel WiFi guide
http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edison_wifi_331438001.pdf http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edison_wifi_331438001.pdf
and a couple of other discussions on the forum. Most of the examples and solutions for enabling Edison softAP mode programmatically are using bash script or system command.
The question consists of two parts. For general embedded WiFi device, when running in SoftAP mode, is it possible to retrieve client RSSI?
If it is possible, does Edison has firmware API or drive allow us to access this info?
Thank you for your input.
Community Manager
Hello RJRPolymer,
You should be able to retrieve the RSSI level if you install iw on your Edison. This package can be downloaded from AlexT's repo. In case you haven't it set up, you can find instructions on how to do it in http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html Edison Package Repo Configuration Instructions. I installed the following packages:
iw
iw-dbg
iw-dev
iw-doc
libiw-dbg
libiw-dev
libiw-doc
libiw30
Using the commands:
opkg install iw
opkg install iw-dbg iw-dev iw-doc libiw-dbg libiw-dev libiw-doc libiw30
After installing this you will be able to check the RSSI level of the desired client with the command: iw wlan0 station get [DEVICE'S MAC ADDRESS]. This is my output:
Peter.
Community Manager
Hello RJRPolymer,
iw
iw-dbg
iw-dev
iw-doc
libiw-dbg
libiw-dev
libiw-doc
libiw30
Using the commands:
opkg install iw
Peter.
IZ1
Hi Peter,
Thanks for your answer. I didn't realize that there is an Edison iw package exists.
