I am very new to using Edison and Eclipse and wanted to integrate the 9DOF on a quad-copter to collect some imu data as an initial test before i begin further integration of the sensor. So far I have be able to complete the following steps for this thread discussion. . but I am still running into issues.
1. connect edison to putty (good)
2. download the src files from github example (good)
3. create a c/c++ project in eclipse (good)
4. copied the files over in the src folder directory (good)
When I try to run the example code I get the following error messages:
Running it on a Windows btw.
Thank you for your help.
I figured out the issue for those who experience the same error. The problem was adding the library to eclipse.
this thread has a similar issue, .
but instead of adding sqlite3, I added mraa.
Hope this helps.
