Hello There,
How do I disable Spread Spectrum clock in intel galileo board ?
Thanks & Regards,
Aravind.
Aravind@ar wrote:
Hello There,
Thanks & Regards,
Aravind.
Hi Aravind,
I'm curious, what is the "Spread Spectrum clock"? what is it used for?
(I've taken at look at http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-galileo-boards/000005735.html Datasheet for Intel® Galileo Board and I did not find any information about it).
Fernando.
Hello Aravind@ar,
Thanks for reaching out!
Do you have any updates about this?
I'd like to insist on Fernando's question, could you please let us know what you mean by Galileo's Spread Spectrum clock? Also, if you could please let us know a little bit more about your project we might be able to help you more accurately.
We'll be waiting for your response.
-Peter.
Hello Peter,
Thank you for response. Sorry for being late on this. We have PCI Bridge connected to Root Port 0 of Quark Soc 1000.
We want to disable the SSC [ Spread Spectrum Clock] for PCI root port 0. Yes the original Quark Soc Data Sheet is not having
any reference to "SSC". However there is Quark Spec Update published Feb 2015
Intel® Quark™ SoC X1000
Specification Update
February 2015
February 2015 Specification Update
Document Number: 329677 Revision: 006
From Spec update above in Page 37, SSCCTL [Spread Spectrum Clocking Control (SSCCTL): 0x14 Target ID: 0x03 ] is defined.
Details below from the Spec update to Quark Soc 1000.. [ I do not have link to document and hence details below ]
Register Missing from Section 14.5 PCI Configuration Registers
Issue: Spread Spectrum Clocking Control (SSCCTL) register is missing from the Intel®
Quark™ SoC X1000 Datasheet.
New Text: Added Section 15.5.54 Spread Spectrum Clocking Control (SSCCTL)
14.5.54 Spread Spectrum Clocking Control (SSCCTL): 0x14 Target ID: 0x03
Register Offset : 0x14
Access : R/W; RO
Register Default: 0000_0000_0000_0000_0000_0000_0000_0000
Affected Docs:Intel® Quark™ SoC X1000 Datasheet
Bit
Range Access Default Fuse
Ovrd Description
31:12 RO 00000h no Reserved: Reserved
11:8 R/W 0h no Reserved: Engineering Reserved
7:4 RO 0h no Reserved: Reserved
3 R/W 0b no
SSC Pattern Halt: Halt generation of the SSC Pattern. Software sets this register field
and waits for at least 32us to allow pattern to finish up its current modulated clock period and
set SSC phase offset back to 0. After this point, software may make update to these register
fields: SSC Max Phase Step, SSC Phase Increment Value, SSC Pattern Repeat Counts, SSC
Spread Mode. Then software clear this register field to restart the hardware SCC pattern.
1: Halt generation of SSC; 0: Allow SSC generation to continually run
2:1 R/W 00b no
SSC Spread Mode: Select the spread mode.
00: Down spread; 01: Center spread; 10: Up spread (RSVD); 11: RSVD
Note: SSC Pattern Halt must be asserted before this control can be
changed.
0 R/W 0b no
SSC enabled: The bit determines whether the entire SSC block is enabled (0) or disabled
(1). When the disabled state is entered all components of the SSC will be shutdown, with the
exception of logic operating in the CRA domain (I.e. config access). The disable state will
only be active when the SSC Reset FSM is in S7 or S0. If this signal becomes a 1 when in S7,
So using the above register SSC can be disabled. However looking at the EDK2 code base, at link https://github.com/tianocore/edk2 https://github.com/tianocore/edk2
I was not sure where to modify the code ? I want to make use of the SSCCTL feature.
regards
Hi Aravind@ar,
In case you are wondering the document can be found here: http://www.intel.com/content/www/us/en/embedded/products/quark/quark-x1000-spec-update.html.
Thank you for clearing up your doubt, it is now clear to me. Please let me investigate about this and if I'm able to find something useful for you I will make sure to share it with you.
-Peter.
Hi Peter,
I am trying to access this SSCCTL register in EDK2 code base, but the offset that is mentioned in quark-x1000-spec-update is in conflict according to PCIe standard for type-1 header (root port).
SSCCTL - offset - 0x14 , but according to PCIE the first 256 bytes are standard configuration registers.
http://wiki.osdev.org/PCI# Configuration_Space http://wiki.osdev.org/PCI# Configuration_Space
http://wiki.osdev.org/PCI_Express http://wiki.osdev.org/PCI_Express
Also the register description says Spread Spectrum Clocking Control (SSCCTL): 0x14 Target ID: 0x03, what is this Target ID - 0x03 ?
Thanks & Regards,
Aravind.
Hi Aravind,
I understand let me try to see what this means. I'll try to get back to you as soon as possible.
-Peter.
Hi Aravind,
The information about how to enable SSCCTL is located in the document CDI# 554070Intel Quark SoC X1000 Family Test and Compliance Tools Guide Rev 0.9, which is available to customers that have an NDA with Intel. The information can be found under chapter 4, and I am able to provide you with the following snippet:
How to control SSC in PCI-E
1.) To control SSC in PCI-E and test it functionality, you may refer to the Intel Quark SoC X1000 Family Test and Compliance Tools Guide Rev 0.9 as below:
http://www.intel.com/cd/edesign/library/asmo-na/eng/554070.htm
2.) To check SSC is enable or disable:
Clocking – SSC is enabled by default.
In the file QuarkSocPkg\QuarkNorthCluster\Include\QuarkNcSocId.h, add the following
define line:
# define QUARK_ICLK_SSC0 0x0214
In the file QuarkSocPkg\QuarkNorthCluster\Library\IntelQNCLib\IntelQNCLib.c, add
the following code to the function PeiQNCPreMemInit in order to disable SSC:
QncIClkOr (
QUARK_ICLK_SSC0,
BIT0 // bit[0] set
Make these changes and re-build the EDK Image.
I hope this information helps you.
-Peter.
Hello Peter,
Thank you for your response.
I made the changes that you have suggested in EDK2 source code and rebuilt the image. But when i boot it, the bios hangs. Please find the below log.
Also the link (http://www.intel.com/cd/edesign/library/asmo-na/eng/554070.htm http://www.intel.com/cd/edesign/library/asmo-na/eng/554070.htm) that you have provide me is not accessible by me.
MtrrSetMemoryAttribute() WB:00000000FF800000-0000000000800000
Status = Success
MTRR Settings
MTRR Default Type: 0000000000000C00
Fixed MTRR[00] : 0000000000000000
Fixed MTRR[01] : 0000000000000000
Fixed MTRR[02] : 0000000000000000
Fixed MTRR[03] : 0000000000000000
Fixed MTRR[04] : 0000000000000000
Fixed MTRR[05] : 0000000000000000
Fixed MTRR[06] : 0000000000000000
Fixed MTRR[07] : 0000000000000000
Fixed MTRR[08] : 0000000000000000
Fixed MTRR[09] : 0000000000000000
Fixed MTRR[10] : 0000000000000000
Variable MTRR[00]: Base=00000000FF800006 Mask=00000000FF800800
Variable MTRR[01]: Base=0000000000000000 Mask=0000000000000000
Variable MTRR[02]: Base=0000000000000000 Mask=0000000000000000
Variable MTRR[03]: Base=0000000000000000 Mask=0000000000000000
Variable MTRR[04]: Base=0000000000000000 Mask=0000000000000000
Variable MTRR[05]: Base=0000000000000000 Mask=0000000000000000
Variable MTRR[06]: Base=0000000000000000 Mask=0000000000000000
Variable MTRR[07]: Base=0000000000000000 Mask=0000000000000000
MTRR Ranges
UC:0000000000000000-00000000000FFFFF
UC:0000000000100000-00000000FF7FFFFF
WB:00000000FF800000-00000000FFFFFFFF
MtrrSetMemoryAttribute() WB:0000000080000000-0000000000080000
Status = Success
MTRR Settings
Variable MTRR[01]: Base=0000000080000006 Mask=00000000FFF80800
MTRR Ranges
UC:0000000000100000-000000007FFFFFFF
WB:0000000080000000-000000008007FFFF
UC:0000000080080000-00000000FF7FFFFF
SecStartupPhase2() Stack Base: 0x8007C000, Stack Size: 0x4000
Register PPI Notify: DCD0BE23-9586-40F4-B643-06522CED4EDE
Install PPI: 8C8CE578-8A3D-4F1C-9935-896185C32DD3
Install PPI: 5473C07A-3DCB-4DCA-BD6F-1E9689E7349A
The 0th FV start address is 0x000FFF10000, size is 0x000F0000, handle is 0x0
Register PPI Notify: 49EDB1C1-BF21-4761-BB12-EB0031AABB39
Register PPI Notify: EA7CA24B-DED5-4DAD-A389-BF827E8F9B38
Install PPI: B9E0ABFE-5979-4914-977F-6DEE78C278A6
Install PPI: CEAB683C-EC56-4A2D-A906-4053FA4E9C16
Install PPI: 6F8C2B35-FEF4-448D-8256-E11B19D61077
Evaluate PEI DEPEX for FFS(9B3ADA4F-AE56-4C24-8DEA-F03B7558AE50)
RESULT = TRUE (Apriori)
Loading PEIM at 0x000FFF1C218 EntryPoint=0x000FFF1C2F0 PcdPeim.efi
Install PPI: 06E81C58-4AD7-44BC-8390-F10265F72480
Install PPI: 01F34D25-4DE2-23AD-3FF3-36353FF323F1
Install PPI: 4D8B155B-C059-4C8F-8926-06FD4331DB8A
Install PPI: A60C6B59-E459-425D-9C69-0BCC9CB27D81
Evaluate PEI DEPEX for FFS(55961E20-B0D9-4553-9948-E3ECF0BE0889)
Loading PEIM at 0x000FFF2014C EntryPoint=0x000FFF2021C PlatformConfigPei.efi
Aravind.
Hi Aravind,
I understand, this link is also accessible under NDA.
Please let me analyze the data you provided me I will back to you.
-Peter.
Hi Peter,
Adding some additional info
I have tested the bios with the suggested changes on Galileo Gen2 board which does not have any PCIE device and also on our custom board which has same SOC as Galileo Gen2 with a PCIE device attached.
On both of these I am observing a similar behavior as shared earlier.
Thanks & Regards,
Aravind.
Hi Aravind,
Thanks for sharing this information, it is of help. I am still investigating what might be happening, I will keep you updated.
-Peter.
Hello Peter,
I hope you will get a chance to analyze the debug provided and suggest a suitable working configuration for SSC disable.
Wishing you Happy new year 2017 ahead.
regards
Hello Aravind,
I can confirm that we have been able to replicate the system halt you saw on a Galileo Gen2. We will continue to work on this and update you as soon as we can.
Happy new year to you too!
-Peter.
Hello Peter,
Can you kindly share any update on the above issue.
I hope there is no issue with the Chipset and Chipset does contain the Register to Disable SSC.
I ask, as when I connect an JTAG debugger and browse I do not find Port 34 (or) Register 34 that is used to Disable SSC.
The CPU / Board seems unresponsive the moment the SSC disable code is executed.
regards
Aravind
Hello Peter,
small correction, it is not Port 34, I am not finding Message Bus Port 32 to which we are writing.
VOID
EFIAPI
QncIClkOr (
UINT32 RegAddress,
UINT32 OrValue
UINT32 RegValue;
// Whenever an iCLK SB register (Endpoint 32h) is being programmed the access
// should always consist of a READ from the address followed by 2 identical
// WRITEs to that address.
RegValue = QNCAltPortRead (QUARK_ICLK_SB_PORT_ID, RegAddress);
RegValue |= OrValue;
QNCAltPortWrite (QUARK_ICLK_SB_PORT_ID, RegAddress, RegValue);
Also I have connected Flyswatter2 debugger to Galileo Gen2 Board and launched Intel System Debugger, the System Controller Register window does not list Message Bus Port 32. So just wondering if indeed the Processor supports SSC feature or not ?
/servlet/JiveServlet/showImage/2-444112-326250/pastedImage_0.png
Thanks & Regards,
Aravind.
Hello Peter,
VOID
EFIAPI
QncIClkOr (
UINT32 RegAddress,
UINT32 OrValue
UINT32 RegValue;
Thanks & Regards,
Aravind.
Hi Aravind,
Thanks for sharing this extra information, it will be of much help.
Unfortunately, I have no updates yet. Nevertheless, we are still working on this, I will update you as soon as possible.
-Peter.
Hi Aravind,
We've noticed that you have opened an IPS case (156685) regarding the same topic as the one discussed in here. We will continue the support through that ticket. This way we will have consistent messaging, and we will avoid the issue of providing you with separate (or worse, different) updates.
We appreciate your patience.
-Peter.
Hi Peter,
Thank you for your support.
Thanks & Regards,
Aravind.
