Intel® Makers
9872 Discussions
Starting Fresh
DHern7
Is there a way that I can start completely fresh with the intel Edison arduino breakout? Ive gone throu the whole etting started process and even blinked the LED in Arduino...A couple monts back. I want to go throu te whole process aain but ow do I in a way factory reset as in fres from the box.
Diego_V_Intel
Hello Roentgenium111,
A "factory reset" would be to re-flash the Edison module. You can flash the Yocto image again using the Flash Tool Lite. You can download it from the following site: https://software.intel.com/en-us/iot/hardware/edison/downloads IoT - Intel® Edison Board Download | Intel® Developer Zone. The Yocto image can be downloaded from the following link: http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip
Diego.
DHern7
My G and H arent the most functional.
Diego_V_Intel
Diego.
