This has to be so simple since googleing for hours didn't give any result.
I successfully uploaded an onboard led blink test project on my Edison using XDK IoT Edition.
Regardless if I stopped it, whenever I turn on the board, the onboard led restarts blinking.
How do I remove the project from the board?
I don't know if it is to be consider a solution, but I found a folder named node_app_slot, deleted all its content, and the onboard led doesn't start blinking at reboot.
Another option is to upload another XDK Project on your board to overwrite the first one. You can also stop or disable the xdk-daemon service.
Sergio
