Intel® Makers
9880 Discussions
Strange value generated by clock() and CLOCKS_PER_SEC
CBrou1
When I get a program to print out the value of CLOCKS_PER_SEC I get1000000 but when I make an approximate measurement with the function clock() in a loop I get to a value closer to 250 !
( i am working with the Eclipse IDE)
Any idea why ?
MGilm
It would be good to provide more details...
I'm assuming you have some kind of software loop that you wrote - can we see it? Any other applicable code we can look at?
Where are you measuring the clock?
How are you measuring the clock - are you using a scope or something else?
Mike
CBrou1
Thanks for your response but please ignore my post. Something was wrong with my initial test ... and the results were spurious
clock() does tick in microseconds. - sorry
MGilm
CABrouwers
That's good to hear. Cheers.
