Hello everybody,
I would like to build up a little surveillance application.
For that, I want the Edison to stream the video form the webcam to my smartphone.
My goal is to maximize the stream quality without any noticeable latency.
The question is, which would be the most suitable way to get this done?
Will there be noticeable performance issues developing a custom solution instead of using Yocto?
(Until now I already have found solution implemented for Yocto.)
Kind regards,
Chris
What solution have you found for Yocto? A good tutorial on streaming in the Edison through Wi-Fi is this one https://github.com/drejkim/edi-cam drejkim/edi-cam · GitHub . Are you planning to use another OS? If you look at you can see the steps another user used using a different OS.
Sergio
Do you have any updates? Were you able to stream via Wi-Fi?
Sergio
