Hi guys,
I'm starting a project that requires my Galileo to take input from a barcode scanner.
I've purchased a USB barcode scanner already that wouldn't even work with Windows 7. I'm going to be a bit more careful with my next purchase. That's where you fine people come in!
Just looking for recommendations on scanners to buy or if anyone has experience with them I would love if they shared!
Thanks in advance,
Poor student who can't afford to waste beer money on barcode scanners
Hello wayneomahony,
I haven't used a USB barcode scanner before, and it's quite difficult to recommend one if I haven't used any, but I found some information that you might find interesting:
- http://www.electroingenio.com/arduino-en/bar-code-scanner-arduino-usb-shield-2/ http://www.electroingenio.com/arduino-en/bar-code-scanner-arduino-usb-shield-2/
- https://www.circuitsathome.com/mcu/connecting-barcode-scanner-arduino-usb-host-shield Connecting barcode scanner to Arduino using USB Host Shield " Circuits@Home
- http://forum.arduino.cc/index.php?topic=226172.0 Barcode scanner from USB to arduino.. no shield
The links above are about Arduino projects with USB barcode scanners. There are some sample codes and hints to choose the USB barcode scanner. As I said, I haven't used a USB barcode scanner, and I'm not sure if the codes shared in the links above work with Galileo, but hopefully they do. You can check them and try to use them with your board.
I hope you find this information useful.
Diego.
Hello wayneomahony,
Diego.
Thanks for the swift reply. I'll check out the links
