Intel® Makers
9880 Discussions
Swap partition on Yocto distributión
MChac
Hi!
I have and Intel Galelio and I tried to create a swap partion on Yocto distribution and when I run the command swapon i get the error message "function is not implemented". Is it possible that it does exist or I am doing something wrong?
Thank you!
masch...
Pedro_M_Intel
Hello masch,
Which image are you using? Did you install swapon? If so, how did you do it?
Or is that what you need to accomplish?
Peter.
Carlos_M_Intel
Hi masch,
Do you have updates on this? Have you been able to use swapon successfully?
Charlie
