Community
cancel
Showing results for
Search instead for
Did you mean:
CDrau
Switch from Uno, Galileo Integrated w. Temboo?
Jump to solution
Planning on switching from Arduino, but I'm not sure I can make the change yet. I've been using Temboo since I first started with the Uno since I'm not big on software coding and they take care of that pretty well. For my new project though, I wanted to go with something bigger and Galileo was better suited for that. However I still want to be able to use Temboo. Does anyone know if they're integrated or have any experience with the two?I want to stream temperature data to Google BigQuery.
Though I'd really prefer to use the Galileo, I might have to look for something else if it means I have to go through the headaches that come with developing code again.
Any help is appreciated!
Tags (1)
JChen218
Hi there,Thanks for using us! I work at Temboo and I'd be glad to help.We don't officially support the Galileo at the moment. You're welcome to try to use our Python SDK on the Linux OS that comes with your Galileo board. You can take a look at this article for more details about trying this:https://learn.adafruit.com/wireless-security-camera-arduino-yun/setting-up-your-arduino-yun https://learn.adafruit.com/wireless-security-camera-arduino-yun/setting-up-your-arduino-yunHere's a link where you can download the Python SDK: https://temboo.com/download https://temboo.com/downloadAnd you can find tutorials for the Python SDK here: https://temboo.com/python https://temboo.com/python
Hopefully this helps, but definitely reach out to us if you have questions or need more information,Jasper
FTinetti
Honored Contributor I
I'm not sure if you are going to be able to maintain your current way of developing applications, but maybe the following thread will give some further hint/s:
There is some Temboo suggested work at too
HTH,
Fernando.
JChen218
