Community
cancel
Showing results for
Search instead for
Did you mean:
Mustafa_A_Intel
Symbol lookup error in sample project
I compiled the sample Fire Alarm project in C++. https://software.intel.com/en-us/articles/how-to-intel-iot-code-samples-fire-alarm-in-cpp How-To Intel® IoT Technology Code Samples: Fire alarm in C++ | Intel® Software
When I try running the project, it copies the executable file to /tmp on Edison, but nothing happens. And, I get the following error when I try running it manually.
root@MustafaEdison:~# /tmp/fire-alarm
/tmp/fire-alarm: symbol lookup error: /tmp/fire-alarm: undefined symbol: _ZN3upm9GroveTempC1Ejf
I have mraa and upm installed on Edison. But opkg does not find a package named libmraa0.
root@MustafaEdison:~# opkg list_installed|grep mraa
mraa - 1.2.3
root@MustafaEdison:~# opkg list_installed|grep upm
upm - 0.7.3
root@MustafaEdison:~# ls -l /usr/lib/libupm-grove.so*
lrwxrwxrwx 1 root root 17 Aug 25 20:44 /usr/lib/libupm-grove.so -> libupm-grove.so.0
lrwxrwxrwx 1 root root 21 Aug 25 20:44 /usr/lib/libupm-grove.so.0 -> libupm-grove.so.0.7.3
-rwxr-xr-x 1 root root 32090 Aug 5 00:29 /usr/lib/libupm-grove.so.0.7.3
I upgraded the libraries in Intel System Studio. The latest online available versions are: MRAA v1.1.2 and UPM v0.7.2.
How can I fix the problem?
Community Manager
Hello MustafaAldemir,
Could you please show us a screenshot of the error message? Also, could you please try to compile the code directly on your board? Do you notice any difference?
-Peter.
Community Manager
Do you have any updates about this?
-Peter.
章顾
i meet it too,
the code :
# include "mraa.hpp"
# include "grove.hpp"
# include "jhd1313m1.h"
//# include "limits.h"
# include
# include
# include
# include
* Grove Starter Kit example
* Demonstrate the usage of various component types using the UPM library.
* - digital in: GroveButton connected to the Grove Base Shield Port D4
* - digital out: GroveLed connected to the Grove Base Shield Port D3
* - analog in: GroveTemp connected to the Grove Base Shield Port A0
* - I2C: Jhd1313m1 LCD connected to any I2C on the Grove Base Shield
* Additional linker flags: -lupm-i2clcd -lupm-grove
* Update the temperature values and reflect the changes on the LCD
* - change LCD backlight color based on the measured temperature,
* a cooler color for low temperatures, a warmer one for high temperatures
* - display current temperature
* - record and display MIN and MAX temperatures
* - reset MIN and MAX values if the button is being pushed
* - blink the led to show the temperature was measured and data updated
void temperature_update(upm::GroveTemp* temperature_sensor, upm::GroveButton* button,
upm::GroveLed* led, upm::Jhd1313m1 *lcd)
// minimum and maximum temperatures registered, the initial values will be
// replaced after the first read
static int min_temperature = INT_MAX;
static int max_temperature = INT_MIN;
// the temperature range in degrees Celsius,
// adapt to your room temperature for a nicer effect!
const int TEMPERATURE_RANGE_MIN_VAL = 18;
const int TEMPERATURE_RANGE_MAX_VAL = 31;
// other helper variables
int temperature; // temperature sensor value in degrees Celsius
float fade; // fade value [0.0 .. 1.0]
uint8_t r, g, b; // resulting LCD backlight color components [0 .. 255]
std::stringstream row_1, row_2; // LCD rows
// update the min and max temperature values, reset them if the button is
// being pushed
temperature = temperature_sensor->value();
if (button->value() == 1) {
min_temperature = temperature;
max_temperature = temperature;
} else {
if (temperature < min_temperature) {
if (temperature > max_temperature) {
// display the temperature values on the LCD
row_1 << "Temp " << temperature << " ";
row_2 << "Min " << min_temperature << " Max " << max_temperature << " ";
lcd->setCursor(0,0);
lcd->write(row_1.str());
lcd->setCursor(1,0);
lcd->write(row_2.str());
// set the fade value depending on where we are in the temperature range
if (temperature <= TEMPERATURE_RANGE_MIN_VAL) {
fade = 0.0;
} else if (temperature >= TEMPERATURE_RANGE_MAX_VAL) {
fade = 1.0;
} else {
fade = (float)(temperature - TEMPERATURE_RANGE_MIN_VAL) /
(TEMPERATURE_RANGE_MAX_VAL - TEMPERATURE_RANGE_MIN_VAL);
// fade the color components separately
r = (int)(255 * fade);
g = (int)(64 * fade);
b = (int)(255 * (1 - fade));
// blink the led for 50 ms to show the temperature was actually sampled
led->on();
usleep(50000);
led->off();
// apply the calculated result
lcd->setColor(r, g, b);
int main()
// check that we are running on Galileo or Edison
mraa::Platform platform = mraa::getPlatformType();
if ((platform != mraa::INTEL_GALILEO_GEN1) &&
(platform != mraa::INTEL_GALILEO_GEN2) &&
(platform != mraa::INTEL_EDISON_FAB_C)) {
std::cerr << "Unsupported platform, exiting" << std::endl;
return mraa::ERROR_INVALID_PLATFORM;
// button connected to D4 (digital in)
upm::GroveButton* button = new upm::GroveButton(4);
// led connected to D3 (digital out)
upm::GroveLed* led = new upm::GroveLed(3);
// temperature sensor connected to A0 (analog in)
upm::GroveTemp* temp_sensor = new upm::GroveTemp(0);
// LCD connected to the default I2C bus
upm::Jhd1313m1* lcd = new upm::Jhd1313m1(0);
// simple error checking
if ((button == NULL) || (led == NULL) || (temp_sensor == NULL) || (lcd == NULL)) {
std::cerr << "Can't create all objects, exiting" << std::endl;
return mraa::ERROR_UNSPECIFIED;
// loop forever updating the temperature values every second
for (;;) {
temperature_update(temp_sensor, button, led, lcd);
sleep(1);
return mraa::SUCCESS;
the CIW:
16:53:30 **** Incremental Build of configuration Debug for project temp2lcd ****
Info: Internal Builder is used for build
i586-poky-linux-g++ "-IE:\\BaiduYunDownload\\edison_all\\edison_all\\IDE\\Intel_System_Studio_Eclipse_based\\Windows\\iss-i.../usr/include/upm" "-IE:\\BaiduYunDownload\\edison_all\\edison_all\\IDE\\Intel_System_Studio_Eclipse_based\\Windows\\iss-i.../usr/include/mraa" -O0 -g3 -Wall -c -fmessage-length=0 "--sysroot=E:\\BaiduYunDownload\\edison_all\\edison_all\\IDE\\Intel_System_Studio_Eclipse_based\\Wind...
Hi, the sensor libraries on your board are out of sync with the IDE. See https://github.com/intel-iot-devkit/upm/issues/470 Symbol lookup error for GroveTemp in C++ · Issue # 470 · intel-iot-devkit/upm · GitHub for a solution to this.
