Intel® Makers
9881 Discussions
System 3.3 V output maximum current (J20-2) Mini Breakout
Community Manager
Some one knows what is the maximum current output of pin J20-2 (System 3.3 V output) of Mini Breakout?
Robbat1
Community Manager
Community Manager
Hi Robbat,
Yes, Flo is right. Taken from the Edison Compute Module HG: "The 3.3 and 1.8 V are power outputs from the Intel Edison module that source a maximum 100 mA each". These values are usually set with certain tolerance, but still I would suggest to stick to the 100 mA from the documentation.
-Pablo
Community Manager
