Intel® Makers
9881 Discussions
System Studio IoT Edition not supported on Window 7 Professional
TStep3
It appears that Windows 7 is no longer supported for installing eclipse with the IoT extensions using System Studio.
Is there a recommended procedure to upgrade Eclipse and the IoT extension/plug in manually?
Community Manager
Hello TJs,
Thank you for interest in the Intel® Edison Breakout Board.
As you probably know, what you find in the Intel System Studio IoT Edition is an Eclipse-based IDE. So anything related to Eclipse and the complementary IoT projects is available here https://www.eclipse.org/ and here https://iot.eclipse.org/.
But you should keep in mind that, since those are not the Edison-recommended versions (the one in System Studio IoT version is the supported version), some issues may or may not arise. What I can recommend is to upgrade your OS (Windows 8 or later), so you can get the adequate support.
Unfortunately, since your OS is no longer supported, there is not a way to upgrade your current version through System Studio IoT Edition.
I'll be waiting for your response.
Andres
