Community
cancel
Showing results for
Search instead for
Did you mean:
MLama4
Tastiera compatibile per Intel Mini PC Intel Cherry Trail 1.84Ghz X5-Z8350 (MOREFINE M1s)
Salve vorrei sapere se questo tipo di tastiera (modello B033 )
( https://it.aliexpress.com/item/Tastiera-portatile-Pieghevole-Senza-Fili-Bluetooth-B033-Inglese-Russo...) è compatibile con questo dispositivo (Mini pc stick "MOREFINE M1s" - Intel cherry trail_ X5-Z8350). In qualche sito mi è parso di capire,ma forse mi sbaglio, che la tastiera in questione non può essere collegata. Nel sito della Intel, tuttavia, si parla di aggiornamento del bios per risolvere il mancato collegamento in alcuni recenti pc stick intel.
Qualcuno può aiutarmi a capire sè vi è un problema ??
Grazie
  1. Mario.
AlHill
It may work, it may not work. It will be for you to determine.
I use this one on my stick, and it works fine:
https://www.amazon.com/Microsoft-Wireless-All-In-One-Keyboard-N9Z-00001/dp/B00IICMUWS https://www.amazon.com/Microsoft-Wireless-All-In-One-Keyboard-N9Z-00001/dp/B00IICMUWS
Doc
MLama4
Grazie -Al Hill
Prenderò in considerazione quella tastiera...se avrò problemi
Per ragioni di spazio quella tastiera pieghevole andrebbe benissimo..
Thanks -Al Hill
I will take that keyboard into consideration ... if I have problems
For reasons of space that folding keyboard would be fine ..
AlHill
It does look interesting. Please report back to confirm if it works or not.
Doc'
n_scott_pearson
Super User Retired Employee
I would add a few things...
First of all, this is not an Intel Compute Stick (ICS) product and thus we know little about its quality or BIOS implementation, so the guidance that we can provide here will be limited. You should really be asking MORE FINE these questions.
Secondly, I have a couple of mini keyboards that I use in my testing of ICS and NUCs that might be good alternatives:
  1. https://www.amazon.com/Rii-Smartphone-mini-X1-BT/dp/B004I4RW8C Amazon.com: Rii Mini Wireless Bluetooth Keyboard Touchpad with Laser Pointer - Using its own dongle, this "remote" works just great with the ICS. I have it working without this dongle on a NUC using its built-in Bluetooth, but have not tried this on an ICS. I will see if I can test this sometime soon and let you know.
  2. https://www.amazon.com/Logitech-Living-Room-Keyboard-Wireless-TV-Connected/dp/B00LBGUVU6 Amazon.com: Logitech Living-Room Keyboard K410, Wireless Keyboard with Built-In Touchpad - I use this (obviously with its own dongle) with both ICS and NUCs. It works great. Logitech has a number of other Bluetooth-compatible mini keyboard products that you could also consider.
  3. https://www.amazon.com/Keyboard-Portable-Professional-Industrial-Computer/dp/B071ZZ5G5Q Amazon.com: MCSaite Super Mini Wired Keyboard - I don't have this exact keyboard, but I do have an older Logitech NetPlay keyboard that is roughly the same size and very similar in layout (I provided this link so you can see the picture). Even though it is intended to support gaming systems, it is still a standard USB keyboard and works great with both ICS and NUCs.
Hope this helps,
MLama4
Thank you
I tried the following model (https://www.ebay.com/itm/B033-Ultra-Thin-Mini-Bluetooth-Wireless-Keyboard-Touchpad-Folding-Three-Lay... B033 Ultra Thin Mini Bluetooth Wireless Keyboard Touchpad Folding Three Layers | eBay ) and it works great in my Morefine M1.
Quick bluetooth connection, working distance max 1.5 m. The structure is resistant. Great product.
