Community
cancel
Showing results for
Search instead for
Did you mean:
AJado
Telnet with Intel Galileo over putty
Jump to solution
I was trying to telnet with the Intel Galileo using Putty , but it seems that port 23 is closed . How do i open the port ? .
Also, i need telnet because i am using phant , which uses telnet to initialize a connection
Tags (1)
Diego_V_Intel
Hello spartacus1806,
I recommend you to try configuring Telnet using the Arduino sketch posted in the following thread: . Please try with the second option that connects the board directly to the router.
Diego.
Diego_V_Intel
Diego.
