Intel® Makers
9881 Discussions
The best GPRS module for Intel Edison
TKret
Hello there,
by your opinion,
what is the best and compatible GPRS module for Intel Edison?
And why?
Thank you in advance,
Taras
mrich4
You can use SIM800L, with AT command from serial, I use Sparkfun GPIO board to send and receive some text
Community Manager
Or you can use some borad from http://www.yoctopuce.com/EN/products/usb-position-sensors/yocto-gps Yoctopuce , this borads are AWESOME and so easy to used.
mrich4
very expensive, SIM800L cost 20x less.........................................
DLaMa
My company (https://www.pretalen.com/ PreTalen) does a lot of research into GPS. We test and characterize a ton of receivers, and I can tell you that U-blox has earned a lot of respect here for their products. (I am not being paid to endorse them.) The M8N is one of the best civilian receivers on the market, but the Ublox 7 is pretty great too. If you have a hub/adapter, they make one that is affordable and has a nice form factor https://www.amazon.com/Diymall-G-mouse-Glonass-Raspberry-Aviation/dp/B00NWEEWW8/ref=sr_1_1?ie=UTF8&q... here.
Then it's as easy as:
>> pip install pyserial
>> python
import serial
gps = serial.Serial('/dev/ttyACM0')
while(True):
print(gps.readline())
You will need to reference someplace like http://www.gpsinformation.org/dale/nmea.htm this to parse out the NMEA data, but that should get you started.
