Intel® Makers
9881 Discussions
The display has stopped working. It just shows no signal on the display??
pChip2
Community Manager
Hello Paul:
We will be more than glad to assist you with that.
What is the specific model of the stick?
Did you try to press F8 several times when the stick is starting up to do a windows recovery?
Did you test a different HDMI cable?
Dis you try to press and hold the power key when you turn the stick on in order to check if we can get in the BIOS?
Did you test it on a different monitor?
Alberto
Community Manager
Hello Minessence:
I just wanted to check if you saw the information requested above?
And also to verify if the problem was resolved or if it still persists?
Alberto
