Intel® Makers
9873 Discussions
The problem with the installation of the latest software
AAndr52
He
I have a problem with Edison , and attempts to load the latest software by using Flash Tool Lite edison is neither visible through the windows as a memory stick or through putty.
I would add that Edison used together with the " Base Block" sparkfun I do not know if this is normal but when you are trying to connect to Edison as a " memory stick " computer several times it seems as if I was putting sounds and take out , ultimately does not recognize it as an Intel Edison.
Pablo_M_Intel
Hi ccesar,
Could you please be a bit more specific? By "latest software" you mean the Edison latest image, right? Do you know what the name of the file is?
Did you already try with the Flashall script method? This is an alternate method to the Flash Tool Lite, I would suggest you to try it.
Here's the link /docs/DOC-25154 https://communities.intel.com/docs/DOC-25154. Let us know if this helps you.
PabloM_Intel
Carlos_M_Intel
Hi ccesar,
Do you have updates on this? Have you been able to use your Edison again?
Charlie
