Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
The right power supply for Edison module+Arduino board
Hi guys,these are the specs (and voltage setting) of my power supply that I want to use with my arduino board.
Can I use it safely?
Highlighted
Yes, that power supply will work on the 7.5,9v or 12v settings. Based on the diagram on the supply, It looks like you can adjust the polarity of the barrel jack plug. You will want to make sure that you have the center of the plug set as + (positive).
Highlighted
Thank you so much for your reply Dan.Do you think that is it better to use a higher voltage (9V) or is 7.5V sufficient?
Furthermore,is 1500 mA safe like power value?Lastly, this is the plug...I think that it's the right one!
Highlighted
Yes, that plug looks correct, and 1500 mA is enough current to power the Edison Arduino board.
Highlighted
Ok ,thanks a lot!
