Intel® Makers
9880 Discussions
Tkinter problem in Intel edison
BKish
I am learning Image processing in intel edison.
Local Host Computer : Windows 7
Installed Yocto Linux (159.devkit) in intel edison
Python 2.7.3
Problem:
Unable to use Tkinter package.
Errors:
"ImportError: No module named _tkinter" # If this fails your Python may not be configured for Tk
"ImportError: No module named Tkinter"
I am quite new to this. Please bare with me.
Bernard_G_Intel
Did you try to do on the Edison board?
opkg update
opkg install python-tkinter
BKish
I tried this. But the issue was not resolved. I am guessing Tk is not configured in python.
Sideralis Is Tkinter working on your edison board?
Bernard_G_Intel
I tried and it is not working neither.
But what do you expect to do with tkinter? I am not too familiar with it but this module is for building graphical interfaces. There is none on Edison so this module would be useless...
BKish
Planning to process images using python numpy, matplotlib to morph images.
Community Manager
Hi bhanukishan,
Thank you for reaching out.
I would like to know if you're following any documentation or tutorial on how to process images with the Edison. Are you using something similar? As Sideralis mentioned, the Edison is not really suited for graphical purposes, however, if it is possible to help you we will definitely try it.
Have you tried using 'pip install'?
opkg install python-pip
pip install tkinter
Also, I would suggest you to update your Edison image for better performance.
-Pablo
Community Manager
Hi bhanukishan,
Do you have updates on this case? Were you able to install tkinter on your Edison?
-Pablo
BKish
No. I stopped following Tkinter as I came to understand that edison doesn't support any graphical interface. But Is there any other solution which will allow us look at the images/2d plots on the console like you see it in ipython or spyder or jupyter?
Community Manager
BKish
Community Manager
We are glad to help you
-Pablo
GWebb
Pablo, I am also trying to configure Tkinter to work on my edison board. Has anyone gotten this loaded and working?
I'm wanting to load it to use the non-graphical "widget.after" module that come with the tkinter package.
-Gary
Community Manager
Hi Gary,
Have you tried using pip install just like Pablo suggested? Did it work?
We will be waiting for your reply.
Have a nice day.
Leonardo R.
