Intel® Makers
9882 Discussions
Transfer incomplete Intel Galileo Gen 2 with SD Card
YElía
Hi everyone!
Well I just got an Intel Galileo and want to use it with a bigger Linux image and controle it by console. I saw a lot of tutorials like this one: http://www.instructables.com/id/Galileo-connect-to-Linux-OS-with-an-ethernet-cable/step4/Upload-the-... http://www.instructables.com/id/Galileo-connect-to-Linux-OS-with-an-ethernet-cable/step4/Upload-the-... but it is giving me a "Transfer incomplete" when I try to upload an sketch to configure Ethernet port in Galileo.
I want to use PuTTY for connection and for this I'm trying to connect by Ethernet. What I have done this far:
  1. Downloaded Linux image (from here: /docs/DOC-22226 https://communities.intel.com/docs/DOC-22226)
  2. Insert SD Card on Galileo
  3. Turn on the Galileo
  4. Wait a while and then connect USB cable on client port
  5. Connect Ethernet between computer and Galileo
  6. Check that port appeared in "Device Manager" (it appears at COM4)
  7. Opened Arduino 1.6 (Menu>Tools>Board>Intel° Galileo Gen 2 | Menu>Tools>Port>COM4)
  8. Made this sketch :
void setup() {
// Start the Telnet Server on Galileo
system("telnetd -l /bin/sh");
//Give Galileo eth0 an IP Address
system("ifconfig eth0 169.254.1.1 netmask 255.255.0.0 up");
void loop() {
// put your main code here, to run repeatedly:
But I'm having this log:
Sketch uses 80,322 bytes (0%) of program storage space. Maximum is 10,000,000 bytes.
# !/bin/sh
# clupload script to invoke lsz
starting download script
# Copyright (C) 2014 Intel Corporation
# ... Here goes all the license, but I didn't want to insert it
echo "starting download script"
echo "Args to shell:" $*
# ARG 1: Path to lsz executable.
# ARG 2: Elf File to download
# ARG 3: COM port to use.
# path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
Deleting existing sketch on target
# COM ports are not always setup to be addressed via COM for redirect.
# /dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadGalileo" > $tty_port_id
# Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
^XB00000000123273^XB00000000123273Retry 0: Got TIMEOUT
^XB00000000000000^XB00000000000000Retry 0: Got TIMEOUT
Transfer incomplete
# Execute the target download command
# Download the file.
host_file_name=$2
"$fixed_path/lsz.exe" --escape --binary --overwrite $host_file_name <> $tty_port_id 1>&0
Transfer incomplete
# mv the downloaded file to /sketch/sketch...
Diego_V_Intel
Hello Yamil_elias,
You can access the console through the serial port. You only need a FTDI cable. Please check the following document for additional details about the serial port and the FTDI cable: http://www.intel.com/support/galileo/sb/CS-035124.htm Intel® Galileo Boards and Kits — Console Serial Cables
On the other hand, I would say, according to your description, that the board is not booting correctly from the SD Yocto image. Could you please take a screenshot of the content of the SD Card? Sometimes, after decompressing the files, some of them are decompressed incorrectly causing the board not booting properly.
Diego.
YElía
Well I solved my issue in other way. I don't own an FTDI cable, that's why I tried to do it by telnet. Anyways, I solve it by connecting a micr USB cable (my phone's charger) to the Intel Galileo and (with the drivers already installed in my computer) it detect it as a Port:
But that was only for connection. About my issue with the Incomplete Transfer it wasn't detecting the Yocto Image. The issue was in the grub.conf file (Located in /boot/grub/). How I solve it was changing only one word in the code to Mass Storage:
default 1
timeout 1
color white/blue white/cyan
title Clanton SVP kernel-MassStorage initrd-SPI IMR-On IO-APIC/HPET NoEMU
kernel --spi root=/dev/ram0 console=ttyS1,115200n8 earlycon=uart8250,mmio32,$EARLY_CON_ADDR_REPLACE,115200n8 reboot=efi,warm apic=debug rw
initrd --spi
title Clanton SVP kernel-MassStorage initrd-MassStorage image-full IMR-On IO-APIC/HPET NoEMU debug
root (hd0,0)
kernel /bzImage root=/dev/ram0 console=ttyS1,115200n8 earlycon=uart8250,mmio32,$EARLY_CON_ADDR_REPLACE,115200n8 reboot=efi,warm apic=debug rw LABEL=boot debugshell=5 rootimage=image-full-galileo-clanton.ext3
initrd /core-image-minimal-initramfs-clanton.cpio.gz
And that's all I hope it helps another one in the same trouble as me.
