Community
cancel
Showing results for
Search instead for
Did you mean:
DSchu9
Trouble shooting Edison power-up on custom expansion board
I'm trying my hand at a first Edison expansion board and failing, however, to get the Edison to power-up. The design is based off of the Sparkfun Edison Base Block (https://cdn.sparkfun.com/datasheets/Dev/Edison/Base_Block.pdf https://cdn.sparkfun.com/datasheets/Dev/Edison/Base_Block.pdf) with the USB interface removed.
Presently when the custom board powers up I see the 3.3V supply from the Edison come up between 150 to 200 ms after VSYS rises to it's supply level of 3.7V. The 3.3V is on and clean for ~150ms before dropping to 0V. There is no activity on the 1.8V supply. Any insight into what sort of fault this indicates would be greatly appreciated.
A few notes...
- PWRBTN# is connected to VSYS using the same resistive divider / reset button network that the Sparkfun Base Block uses.
- DCIN is wired directly to VSYS.
- FAULT is wired directly to GND.
Any suggestions would be appreciated.
Thanks!
Community Manager
Hi drschuet,
Could you please tell us how you're powering the custom board? Are you using a battery or an external power supply? Sometimes the issue could be related to the power source not being enough for the board. Sometimes, when a feature (e.g: WiFi) starts the boot process just stops or hangs, so you could consider that option and try with a different supply.
Pablo
DSchu9
Naively I'd think there is enough power there. If I watch the VSYS trace along with the 3.3V on the scope I see no ripple or drop-out in either.
VSYS is being supplied by a MIC39102YM low drop-out adjustable regulator (http://www.micrel.com/_PDF/mic39100.pdf http://www.micrel.com/_PDF/mic39100.pdf) with a 20kOhm (R1), 10kOhm (R2) restive divider network (fig. 2 of data sheet) with a 10 uF by-pass cap on the output. This network gives an VSYS of 3.7 V. In testing I am using an Agilent programmable power supply to source the input voltage for the regulator (current limit set to 1A). In operation it will be a 3A power brick.
- Dan
Community Manager
Hi drschuet,
Thank you for the explanation. If that's the case, I would suggest you to check the DCIN and VSYS connection once more to see if it's correct, as you can read in the Edison Module Hardware Guide, DCIN indicates whether the Edison is being powered from a battery or from an external supply. It also sets the voltage level required on VSYS in order to boot. According to your description DCIN is connected to VSYS, but the current behavior that you're getting sound very similar to this part of the text: "VSYS must rise from 2.5 to 3.5V in 10ms; otherwise the boot is aborted".
Pablo
Community Manager
I would also suggest you to check this thread, you might find some new information, /thread/59916 https://communities.intel.com/thread/59916.
Pablo
DSchu9
Hi Pablo,
Thank you for the help. After checking all the above I discovered the problem. My custom expansion board is a two layer board with power and ground fill instead of ground planes. Solder from one of the SMD connections was bridging the gap between a pad and a piece of power fill that was not fully covered at the edge by the PCB silkscreen. This was causing a short between 1.8V and GND resulting in the Edison's boot failure. Things appear to be working now.
One small suggestion / request. I have found very little information on the PMIC used in the Edison, I understand that it is a custom part. A diagram of the power-up sequencing could be useful in debugging problems like what I ran into.
In any case, thank you for the help!
- Dan
Pablo_M_Intel
Hi drschuet,
I'm really glad to know that you were able to solve the issue with our suggestions.
Regarding the PMIC documentation, this is a TI component (more specifically SNB9024) and given that this is a non-distributor item there is no documentation available for it. This was their reply to another user some time ago:
Thank you for contacting TI Semiconductor Support.
Unfortunately, since this is a non-distributor item, there is no documentation available for the SNB9024 device (datasheets, user guides, etc.).
Pablo
