Hello, all I have two things that I'm trying to bring together. A Morse Code Decoder, ie. an Arduino program that takes the pushes of a momentary push button into a dit if it's a short press or dah if it's a long press, and dynamically decodes the sequence of Morse Code characters into their respective English character representations and displays it on 16x2 LCD screen. I will paste my code here. I've refactored the code but it may still be confusing so feel free to ask me questions. Also I should say that it depends on special hardware from one of Grove's developer kits, but I don't have to change any of their hardware configurations and the code that controls the hardware should be commented on what it's doing in the context of the program:
//Note: this program uses an LCD screen and a momentary pushbutton from the Grove Kit
# include
# include "rgb_lcd.h"
//hardware constants
rgb_lcd lcd;
const int colorR = 66;
const int colorG = 241;
const int colorB = 244;
const int buttonPin = 3;
// Set the timer system for the button presses
long buttonPressTime = 0;
long longPressTime = 1000; //a long button press is one second, in this morse code implementation
unsigned long previousMillis = 0; // will store last time LED was updated
const long interval = 10000; // interval at which to decode a new morse code character (milliseconds)
//variables for the decoding algorithm
String morseVals = String(""); //where I will store each morse character that the user enters, will be passed to the loop statement
char englishChar = ' ';
//Text state of the LCD
int morseColumn = 0;
int englishColumn = 0;
const int MORSE_ROW = 0;
const int ENGLISH_ROW = 1;
// Set the state system of the button presses
boolean isButtonActive = false; // for telling if the button is being pressed so that we only have to use digitalRead() once
boolean isLongPressActive = false;
//helper function for reseting the first row
void resetMorseRow() {
for(int i = 0; i < 5; i++){
lcd.setCursor(i, MORSE_ROW);
lcd.print(" ");
morseColumn = 0;
lcd.setCursor(morseColumn, MORSE_ROW);
void setup()
// set up the LCD
lcd.begin(16, 2);
lcd.setRGB(colorR, colorG, colorB);
//lcd.cursor(); //makes the cursor where the next character will be printed at, but only useful for debugging as it looks too much like a dah
lcd.setCursor(0, 0);
void loop()
morseDecoder();
void morseDecoder() {
if (digitalRead(buttonPin) == HIGH) { // if the button is being pressed ...
if (isButtonActive == false) { // if the last saved state of the button was set to false i.e it's the first run of the program ...
isButtonActive = true; // set it to true
buttonPressTime = millis(); // save the time when the button was pressed
if ((millis() - buttonPressTime > longPressTime) && (isLongPressActive == false)) { // if the current time - the time the button was pressed is the long button press time
// AND the last saved state of the Long button press is set to false (to avoid recording two long presses)
isLongPressActive = true; // set the state of isLongPressActive to true
lcd.setCursor(morseColumn++,MORSE_ROW); // specify the next column in the "morse row"
lcd.print('_'); // print a dah
morseVals = morseVals + "_";
else { // happens if the long press case failed
if (isButtonActive == true) { // if the button is being pressed
if (isLongPressActive == true) { // if the long press state is set to true ...
isLongPressActive = false; // set it to false
else {
lcd.print('.'); // print a dit
morseVals = morseVals + ".";
isButtonActive = false; // set button active to false (we don't check how short a short press is)
//it is my understanding that the character timer does not depend on whether or not a button was presses, just time so save the time for each interval
unsigned long currentMillis = millis();
if ((currentMillis - previousMillis >= interval) || (morseVals.length() >= 5) ) { //TODO: this if statement works as a delay right now, but I should I should actually reset the timer whenever the user presses the button
// save the last time you printed an english character
previousMillis = currentMillis;
// print the character now and move up one row once you finish
//declare the big switch case here
if(morseVals.equals("._")){
englishChar = 'A';
else if(morseVals.equals("_...")) {
englishChar = 'B';
else if(morseVals.equals("_._.")) {
englishChar = 'C';
else if(morseVals.equals("_..")) {
englishChar = 'D';
else if(morseVals.equals(".")) {
englishChar = 'E';
else if(morseVals.equals(".._.")) {
englishChar = 'F';
else if(morseVals.equals("__.")) {
englishChar = 'G';
else if(morseVals.equals("....")) {
englishChar ...
- Tags:
- Servers
Hi RobertoGarcia,
I'm not completely sure I understand your problem/question. Specifically about a web server on the Intel Galileo, I suggest you do not use any code based on the Arduino Ethernet shield, mostly because the Intel Galileo Ethernet I/O does not have any relationship to the SPI port. Take a look at ,
Are you planning to "replace" physical buttons by a web interface?
HTH,
Fernando.
Hello, Fernando,
I am planning to not replace the physical momentary pushbuttons on the web page interface. I want both buttons on the web server and the pushbuttons to do the same functions, send Morse Code characters, either dits or dahs. I just don't know how to write the function that will be used on the web interface.
I'm not using the web ethernet shield, what I'm doing is connecting the ethernet shield straight to the PC computer I'm debugging with from the ethernet port that is built-in to the Intel Galileo board. Because this is the only way I know how to setup a server I would like to do it similarly:
Program: eth_websrv_LED
Description: Arduino web server that serves up a web page
allowing the user to control an LED
Hardware: - Arduino Uno and official Arduino Ethernet
shield. Should work with other Arduinos and
compatible Ethernet shields.
- LED and resistor in series connected between
Arduino pin 2 and GND
Software: Developed using Arduino 1.0.3 software
Should be compatible with Arduino 1.0 +
References: - WebServer example by David A. Mellis and
modified by Tom Igoe
- Ethernet library documentation:
http://arduino.cc/en/Reference/Ethernet http://arduino.cc/en/Reference/Ethernet
Date: 11 January 2013
Author: W.A. Smith, http://startingelectronics.org http://startingelectronics.org
# include
# include
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0x98, 0x4F, 0xEE, 0x00, 0x2F, 0x0F };
IPAddress ip(); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
String HTTP_req; // stores the HTTP request
boolean LED_status = 0; // state of LED, off by default
void setup()
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(9600); // for diagnostics
pinMode(LED_BUILTIN, OUTPUT); // On board LED
void loop()
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
HTTP_req += c; // save the HTTP request 1 char at a time
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// send web page
client.println("<!DOCTYPE html>");
client.println("");
client.println("");
client.println("Arduino LED Control");
client.println("");
client.println("");
client.println("LED");
client.println("
Click to switch LED on and off.
");client.println("");
ProcessCheckbox(client);
client.println("");
client.println("");
client.println("");
Serial.print(HTTP_req);
HTTP_req = ""; // finished with request, empty string
break;
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
// switch LED and send back HTML for LED checkbox
void ProcessCheckbox(EthernetClient cl)
if (HTTP_req.indexOf("LED2=2") > -1) { // see if checkbox was clicked
// the checkbox was clicked, toggle the LED
if (LED_status) {
LED_status = 0;
else {
LED_status = 1;
if (LED_status) { // switch LED on
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
// checkbox is checked
cl.println("
onclick=\"submit();\" checked>LED2");
else { // switch LED off
digitalWrite(LED_BUILTIN, LOW);
// checkbox is unchecked
cl.println("
onclick=\"submit();\">LED2");
Hi RobertoGarcia,
Something sounds strange in
I think it does not make any sense to have both buttons on the web server... who and how send the code characters? and to what other site/application would the web server sent those characters to? Maybe you mean having the buttons in the web interface or web browser where a user may click/select any of them and send it to the web server?
What do you mean by "the function that will be used on the web interface"? Wouldn't be enough to have two web buttons at the web interface? If it is the case, it is not related to Intel Galileo but to web programming/web site design. It's not a problem if that's the case, It's just for making clear the problem/question.
About
Again I'm lost... if you are using an Intel Galileo then you don't have any Ethernet shield...
Do you know the code you included in your post or you are asking about some explanation on it? Actually, if all you want in the web browser are the two Morse dit and dah, then two submit buttons are all you need... or maybe I misunderstood your post... sorry.
Maybe it would be helpful if you describe the web interface for the user on one side and the web server behavior for that web interface on the other...
HTH,
Fernando.
Hi, sorry about the confusion. My assignment is for the user to be able to decode their morse code with both options, the web page that the intel galileo serves and the physical buttons on the galileo board. By buttons on a web browser I mean such as the following syntax:
Send dit
And once the user sends those buttons the program will decode the characters into their English characters.
Yes this is what I mean, the user would "send" the characters to the Intel Galileo server, and then the rest of the server computes the logic of it, which is the part I'm having trouble getting started. Like, how would Iretrieve the characters once the user sends them by pressing the web buttons. This is similar to my LCD server code, where the guide I got it from did this:
if (LED_status) {
LED_status = 0;
else {
LED_status = 1;
cl.println("
cl.println("
Except instead of a checkbox that turns an LED off or on, how do I get the web buttons to transmit characters back to the server, which it will then process in the form of decoding.
Nextly, sorry I meant to say that I plugged the ethernet port on one end to my PC laptop into the ethernet port on my Galileo. It's the one built-in, not an ethernet shield. I guess my question is about web design/programming and also howto bring it together with Arduino code. I'm new to networking and server programming. Let me know if I may have missed something.
Hi RobertoGarcia,
Now I think we are in the same page. I think you may use a web page like this one:
Morse Code
Text:
(you can copy the text and save it to index.html in order to have a quick look at it). The "meta" in the html head would help to see the web page in cell phones and tablets.
Taking this html as a "departure point" you would be able to add the decoded characters after "Text: ". Actually, if you take a look at the link I included in a previous post ( ) you may read in the last post of the thread how to use the .html in a file, read it and send it to the client from the web server running in the Intel Galileo. However, you will have to process each client request in a similar way of what you are doing now with the led, but storing the "." and "-" in a string and decoding it in a way similar to that you included in the code in the first post.
HTH,
Fernando.
