Community
cancel
Showing results for
Search instead for
Did you mean:
GIrac
U-Boot 2017.03 Won't Boot
Just wanted to see if anyone here has experience with Andy Shevchenko's (0andriy ) U-Boot fork. We've gotten it to compile and build, but when we flash it to the Edison it just prints a single newline and hangs forever. We're loading over U-Boot 2014.04 and are running truncate -s %4096 as his instructions here ( ) indicate. We've built a 4.10 (?) kernel using his sources, but can't get it to load without an up to date U-Boot. I figure it's not officially supported by Intel, but has anyone been able to get U-Boot 2017.0X working?
Andriy_S_Intel
Thank you for trying it. I know at least 3 independent people who manage to update their U-Boot (besides that fact I had managed many times).
So, can you, please, elaborate what exactly you did and what you get?
GIrac
This is our current build process:
$ git clone https://github.com/andy-shev/u-boot.git
$ cd u-boot
$ git checkout edison
$ # Fix compilation error in sdram.c
$ git diff
diff --git a/arch/x86/cpu/tangier/sdram.c b/arch/x86/cpu/tangier/sdram.c
index 9ff7d53..ce0f2bc 100644
--- a/arch/x86/cpu/tangier/sdram.c
+++ b/arch/x86/cpu/tangier/sdram.c
@@ -120,8 +120,8 @@ static struct sfi_table_simple *sfi_search_mmap(void)
error("failed to locate SFI MMAP table\n"); \
(mentry) = (struct sfi_mem_entry *) (sb)->pentry; \
- for (int i = 0; i < SFI_GET_NUM_ENTRIES((sb), \
+ int i; \
+ for (i = 0; i < SFI_GET_NUM_ENTRIES((sb), \
struct sfi_mem_entry); i++, (mentry)++) \
static unsigned sfi_setup_e820(unsigned max_entries, struct e820entry *entries)
$ make edison_defconfig
$ make
$ truncate -s %4096 u-boot.bin
$ # Run the script to generate u-boot-edison.img, uncommenting line 21: https://gist.github.com/andy-shev/2c388310f2773ead647d9c1a3f1c813f Create U-Boot image suitable for xFSTK and DFU for Intel Edison · GitHub
$ mv u-boot.bin u-boot-edison.bin
$ cp u-boot-edison.* ../toFlash/
$ cd ../toFlash
$ # Unplug and replug Edison
$ sudo ./flashall.sh --recovery
$ sudo screen /dev/ttyUSB0 115200
We get the ROM boot message:
PSH KERNEL VERSION: b0182727
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 23:15:13 Apr 24 2014
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
<span class="s1...
Andriy_S_Intel
Instead of
./flashall --recovery
simple run
xfstk-dldr-solo --gpflags 0x80000007 --osimage u-boot-edison.img --osdnx edison_dnx_osr.bin
Note: it might fail and you need to restart few times.
GIrac
Doesn't seem to help. I got it to work once, but I tried to flash with a new filesystem image and after that it stopped working. Not really sure why. I still get the ROM boot message and a single newline. I tried to reset everything by reflashing with a known working image with 2014.04 then deleting the u-boot repo and starting from scratch, but it didn't help. I've tried making the image both with and without the truncate step and it still doesn't boot.
Andriy_S_Intel
Let me check here with another (clean) board.
First of all, I have checked that everything is pushed to my Github repository:
$ git push -f gh-andy-shev
Everything up-to-date
Then, I re-flashed board with official Edison BSP (iot-devkit-prof-dev-image-edison-20160606):
$ ./flashall.sh --recovery
Using suffix
Starting Recovery mode
Please plug and reboot the board
Flashing IFWI
and
$ ./flashall.sh
Using suffix
Using U-Boot target: edison-blankcdc
Now waiting for dfu device 8087:0a99
Flashing IFWI
After boot and reboot I have checked the version of U-Boot:
U-Boot 2014.04 (Jun 06 2016 - 14:40:07)
Interrupted to get U-Boot shell and run:
boot > run do_force_flash_os
Saving Environment to MMC...
Writing to redundant MMC(0)... done
GADGET DRIVER: usb_dnl_dfu
DFU complete CRC32: 0xf340088e
DOWNLOAD ... OK
Ctrl+C to exit ...
On the host:
$ make clean && make edison_defconfig && make -j16
$ dfu-util -v -d 8087:0a99 --alt u-boot0 -D u-boot.bin
Again in U-Boot shell:
boot > reset
resetting ...
PSH KERNEL VERSION: b0182b2b
WR: 20104000
microkernel built 11:24:08 Feb 5 2015
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
U-Boot 2017.03-rc3-00012-ge6566cddc9 (Mar 01 2017 - 21:01:06 +0200)
CPU: x86_64, vendor Intel, device 406a8h
DRAM: 980.6 MiB
MMC: mmc@ff3fc000: 0, mmc@ff3fa000: 1
In: serial@ff010180
Out: serial@ff010180
Err: serial@ff010180
Net: Net Initialization Skipped
No ethernet found.
Hit any key to stop autoboot: 0
I dunno what you, grantira, are doing, but I have seen no issues.
GIrac
After giving up for a few days, we followed your steps on a different machine and it just worked. Still no idea what was wrong, but at least we have it working. Thanks for your help and all of your work on U-Boot and the kernel. It's pretty awesome.
