Community
cancel
Showing results for
Search instead for
Did you mean:
Chris_S_Intel
UART BYTE Datatype @ 1Mbps - Dynamix Servo
Jump to solution
Overview: Recently purchased a Dynamixel AX-12W servo and attempting to build custom library since not able to find for Edison. These servos require a half-duplex UART connection at 1Mbps and plan to use tri-state buffers (FairSemi 74F244) and GPIO control to convert half-duplex from servo to full-duplex into Edison. This will allow both instructions to be sent and status to be returned using a single wire.
Note: I have already confirmed on oscilloscope that I can transmit char at 1Mbps with no issue (8bit, no parity, 1stop).
Problem: The servos expect bytes to be sent instead of char. Pseudo code below to show simple instruction packet.
LINE 1 DIRECTION_PORT = TX_DIRECTION //Set tri-state buffer to High-Z for Rx, and enable Tx.
LINE 2 TxDByte(0xff); //Notifies beginning of packet - part 1
LINE 3 TxDByte(0xff); //Notifies beginning of packet - part 2
LINE 4 TxDByte(bID); //ID of the servo to be addressed
LINE 5 TxDByte(bLength); //length is calculated as "the number of Parameters (N) + 2
LINE 6 TxDByte(bInstruction); //instruction ID
LINE 7 TxDByte(Parameter0); TxDByte(Parameter1);
Question: Is there a way to use mraa_uart_write(uart, buffer, sizeof(buffer)) definition or other mechanism to send bytes instead of char?
Suggestion: I was thinking about reverse engineering the char ASCII table to create a mapping to get the byte definitions I needed, but this would be quite ugly and not sure possible as 0xFF undefined and needed to notify beginning of packet.
Dynamix Reference:
http://support.robotis.com/en/techsupport_eng.htm# product/dynamixel/ax_series/dxl_ax_actuator.htm TechSupport_ENG
http://support.robotis.com/en/product/dynamixel/dxl_communication.htm Overview of Communication
MLópe2
A char and a byte are the same.
You can use char as bytes without problems.
char data = 0x01
MLópe2
char data = 0x01
Chris_S_Intel
Thanks Miguel this worked. For anyone trying to use Dynamix with Edison here is some reference code for transmitting command.
mraa_gpio_write(mstrPin_TX, 1); //set transmit for half-duplex to full-duplex converter logic
mraa_gpio_write(mstrPin_RX, 0);
char packet_start1[1] = {'\xFF'};
char packet_start2[1] = {'\xFF'};
mraa_uart_write(mstrComm_UART, packet_start1, sizeof(packet_start1));
mraa_uart_write(mstrComm_UART, packet_start2, sizeof(packet_start2));
mraa_uart_write(mstrComm_UART, _command.ID, sizeof(_command.ID));
mraa_uart_write(mstrComm_UART, _command.Length, sizeof(_command.Length));
mraa_uart_write(mstrComm_UART, _command.Instruction, sizeof(_command.Instruction));
mraa_uart_write(mstrComm_UART, _command.Param_Address, sizeof(_command.Param_Address));
char data_packet[1];
for (int i = 0; i < _command.Count_Param_Data; i++) {
data_packet[0] = _command.Param_Data[i];
mraa_uart_write(mstrComm_UART, data_packet, sizeof(data_packet));
mraa_uart_write(mstrComm_UART, _command.Check_Sum, sizeof(_command.Check_Sum));
mraa_gpio_write(mstrPin_TX, 0); //set receive for half-duplex to full-duplex converter logic
mraa_gpio_write(mstrPin_RX, 1);
