Community
cancel
Showing results for
Search instead for
Did you mean:
LGlaz
UART baud rate clarification
I've seen a number of discussions and documents related to the D2000 UART baud rate settings. This includes these documents that describe the settings/equations in detail...
https://software.intel.com/en-us/articles/using-uarts-on-intel-quark-microcontroller-d2000 Program UART Interfaces on the Intel® Quark™ Microcontroller D2000 | Intel® Software
https://software.intel.com/sites/default/files/managed/9b/02/D2000%20-%20Change%20the%20Baud-rate%20... https://software.intel.com/sites/default/files/managed/9b/02/D2000%20-%20Change%20the%20Baud-rate%20...
All show the equations for the baud rate calculation based on the system clock, divisor and fractional divisor.
However, only the datasheet (page 179) states...
Baud Rate configurability between 300 baud and 2M baud.  Maximum baud rate is limited by system clock frequency divided by 16.  Supported baud rates: 300, 1200, 2400, 4800, 9600, 14400, 19200, 38400, 57600, 76800, 115200; multiples of 38.4kbps and multiples of 115.2kbps up to 2M baud
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/quark-d2000-datasheet.pdf https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/quark-d2000-datasheet.pdf
I've been trying to operate the D2000 at 500Kbps (divisor 4, fdivisor 0). It hasn't been working out very well, so I'm wondering if the datasheet statement of "multiples of 115.2kbps up to 2M baud" might be the culprit. Can anyone shed light on whether or not the UART hardware requires operation in the multiples stated in the datasheet? I assumed it was based entirely on the dividers and system clock, in which case I don't need to use a standard baud rate, and can use one with less error at a higher speed.
I've been interfacing to a modem using software at 500Kbs without any problems. But the D2000 shows bit errors with in each byte received when I use it in place of the test software at the higher baud rate.
Shah_Intel
We are in progress on investigating.
Thank you,
Intel Customer Support
Shah_Intel
Hi LonGlazner,
May I know?
1) What is the test software are you using?
2) Which higher baud rate that you use?
3) Do you use the cable compatible support higher baud rate?
4) How about 500kbs with D2000?
Thank you,
