I am trying this two functions (line 6 and 7) and both gave different results!
# define MyString ("AT\r\n")
qm_uart_write_buffer(QM_UART_0, (uint8_t *)MyString, sizeof(MyString));
QM_PRINTF("AT\r\n");
qm_uart_write_buffer(QM_UART_0, (uint8_t *)aString, sizeof(aString)); output : AT\r\n0
while QM_PRINTF("AT\r\n"); output : AT\r\n
FYI, I have used QM_UART_LC_8N1 = 0x03, /**< 8 data bits, no parity, 1 stop bit */ for Configuration. And there shouldn't be additional 0 at the end.
Wasted few hours debugging hardware while apparently it was software error!!
Hi ByteMaster,
I tried to reproduce back your issue but it seem like there no issue on my machine. Could you try to repair/reinstall back the ISSM 2016 to see if the issue still persist. If yes, please help to provide more details on the setup to reproduce back the issue.
Soffi
Hi Soffi,
Try with Logic analyzer or oscilloscope..it appears in there.
Hi ,
It seems you are also seeing the null character that marks the end of the string -- Do you see the same issue is you use strlen rather than sizeof to calculate the length ?
It seems ok for me ..
# include
# include
# include
int main(void)
qm_uart_write_buffer(QM_UART_0, (uint8_t *)MyString, strlen(MyString));
return 0;
regards,
Michelle.
Hi Michelle,
This make sense.
it works with strlen instead of sizeof
Please check the output of this three lines in attached pic.
qm_uart_write_buffer(QM_UART_0, (uint8_t *)MyString, sizeof(MyString)); /* Send "AT\r\n" */
qm_uart_write_buffer(QM_UART_0, (uint8_t *)MyString, strlen(MyString)); /* Send "AT\r\n" */
QM_PRINTF("AT\r\n"); /* Print "AT\r\n" */
