Community
cancel
Showing results for
Search instead for
Did you mean:
BMist2
UART0 Enable and Disable for D2000
Hi All,
How to Enable and Disable ONLY UART peripheral in Intel Quark D2000?
To Enable:
/* Enable peripheral clock and UARTA */
clk_periph_enable(CLK_PERIPH_CLK | CLK_PERIPH_UARTA_REGISTER);
and to disable:
/* Disable peripheral clock and UARTA */
clk_periph_disable(CLK_PERIPH_UARTA_REGISTER);
or it need to disable both Peripheral clock and UART module too?
clk_periph_disable(CLK_PERIPH_CLK | CLK_PERIPH_UARTA_REGISTER);
Also,
How much Current is drawn when UART module is Enabled?
Oliver_M_Intel
Hi
The code you have listed above for enabling the UART interface is correct. To disable you only need to specify the UART interface:
Including CLK_PERIPH_CLK will disable all peripherals.
We will get back to you on the current question.
Oliver
BMist2
Hi Oliver,
Thank you for reply.
However I tried by removing following line from UART configuration
and surprisingly UART functions still works!
Could you plz check if that's is the case with you too?
Thank you
Oliver_M_Intel
Hi
Apologies for the delay in getting back to you. Once the main clock has been enabled by the hardware, the peripheral clocks to UART and SPI are enabled hence why you were able to use the UART function without explicitly enabling it in your code first. This is explained in more detail in section 7.2.5 of the D2000 Datasheet.
Regarding the query about how much current is drawn when UART is enabled, this very much depends on the design of your platform which is using the UART interface on the D2000. Is you query related to the MCU silicon itelf, or the overall board platform? The silicon figures we have would not take into account IO considerations etc.
Oliver
