Intel® Makers
9880 Discussions
[UPM] UPM hp20x library
LGran2
Hello everyone!
I have bought a grove barometer (this one: http://wiki.seeed.cc/Grove-Barometer-High-Accuracy/ Grove - Barometer (High-Accuracy) - Seeed Wiki) and I'm really interested in using the UPM library hp20x to use it.
I tried the following git example : https://github.com/intel-iot-devkit/upm/blob/master/examples/c%2B%2B/hp20x.cxx upm/hp20x.cxx at master · intel-iot-devkit/upm · GitHub.
The build of this program doesn't work but I think I do it the wrong way, can you help me?
I tried several commands as :
- g++ test.cpp -lmraa -Wall
- g++ test.cpp -lmraa -lupm -Wall
- g++ test.cpp -lmraa -lupm-hp20x
None of these works.... I get this error : "Couldn't find hp20x.hpp". I checked, and I have a hp20x.so in my /usr/lib directory!
What can I do?
Thank you for your help!
Leo
Community Manager
Hi Grany,
Thanks for your interest in the Intel® Edison™ Platform.
I'm sorry to hear that you are having problems compiling the hp20x sample code. I started to investigate and I found this tutorial (http://shawnhymel.com/756/writing-your-own-upm-module-getting-started/ Writing Your Own UPM Module: Getting Started | Shawn Hymel ), after reading through out the guide, I concluded that this command: g++ hp20x.cxx -lupm-hp20x -I/usr/include/upm was the one that I needed, fortunately it compiled! You should know that after the compilation is over it generates a "a.out" file, this your executable file, so in order to try it use this command: ./a.out .
Now, unfortunately, I don't have this barometer at hand, so I can't test it out. Could you be so kind to test it, in order to see if this sample code works.
I will be waiting for your reply, have a nice day!
-Jose P.
Community Manager
Hi Grany,
-Jose P.
LGran2
Thank you for your answer!
It works really fine!
Leo
Community Manager
Hi Leo,
I'm glad to hear that it worked! Please don't hesitate to contact us back if any questions come up.
Have a great day!
-Jose P.
