Intel® Makers
9882 Discussions
USB AUDIO card not powering with edison
SRasa
Valued Contributor I
I am trying to connect a USB audio card to the USB port on edison but it does not power up! Do I have set any jumper setting to get the audio card working?
Pedro_M_Intel
Hello Sriranjan,
How are you powering the audio card, usually the Edison's output power is not enough to power up a peripheral such as this, and probably that's what happening to you.
Also, remember that if you want to use the Edison as host, the Edison's micro-switch must be facing the full-USB port, otherwise the USB port won't even be enabled and you won't be able to the detect the peripheral.
If the issue is the power of the audio card then remember to wire together the audio card's ground to the Edison's ground, otherwise the audio card won't receive the Edison's signals.
Peter.
Pedro_M_Intel
Hello Sriranjan,
Peter.
SRasa
Yeah it is working now. Earlier I was trying to power it up from the USB ports but now when I put the power adapter and turned the micro-switch to the other side it started working.Thanks.
