Community
cancel
Showing results for
Search instead for
Did you mean:
MClif
USB Cable connecting: Micro USB B before USB A
Jump to solution
Looking at the following pages, the first is text, the second is a video:
They each describe plugging the micro USB B connector into J16, or J3, FIRST and THEN plugging the USB A connector of that cable into the PC.
Question: Must the USB B connector be plugged into J16/J3 FIRST before plugging in USB A into the PC to avoid a static discharge at the Edison/Arduino end of the cable?
Bill
Tags (1)
Diego_V_Intel
Hi Bill,
In many occasions I've plugged the USB cable to the PC first and then to the Edison board, and I haven't had any kind of issue about static discharge so I would say that there is no difference if you connect the USB A connector first or the USB B connector.
Diego
Diego_V_Intel
Hi Bill,
Diego
