Intel® Makers
9868 Discussions
USB Host Mode Compilation problem
RDenb
I have an Edison Arduino board (the big one that takes shields and has a full size type A USB port on it).
I am trying to use the Type A USB socket in Host mode, for a WiFi dongle, but I'm having difficulty compiling the kernel - I hope somebody here may be able to help please.
Edison Source from here:
wget http://downloadmirror.intel.com/25028/eng/edison-src-ww25.5-15.tgz http://downloadmirror.intel.com/25028/eng/edison-src-ww25.5-15.tgz
Kernel Source from here:
wget https://www.kernel.org/pub/linux/kernel/v3.0/linux-3.10.17.tar.bz2 https://www.kernel.org/pub/linux/kernel/v3.0/linux-3.10.17.tar.bz2
Then I unpack each of those and added the patch:
cd linux-3.10.17
patch -p1 < ../edison-src/meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux/files/upstream_to_edison.patch
I used the supplied defconfig:
cp ../edison-src/meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux/files/defconfig .config
I have to copy some files
cp ./drivers/tty/serial/mfd_trace.h include/trace/
cp ./sound/soc/intel/sst/sst_trace.h include/trace
at this point if I make the kernel, all is good.
However, in menuconfig the "DWC3 Mode Selection" is "Gadget only mode"
Is it the case that I should change that to enable host mode?
When I make that change to Host only mode (dual mode has the same end results), .config changes as follows:
< CONFIG_USB_DWC3_HOST=y
< # CONFIG_USB_DWC3_GADGET is not set
> # CONFIG_USB_DWC3_HOST is not set
> CONFIG_USB_DWC3_GADGET=y
The problem is then that when I try to compile I get errors that I don't understand:
make -j8
scripts/kconfig/conf --silentoldconfig Kconfig
make[1]: Nothing to be done for 'all'.
CHK include/generated/uapi/linux/version.h
make[1]: Nothing to be done for 'relocs'.
CHK include/generated/utsrelease.h
CC scripts/mod/devicetable-offsets.s
GEN scripts/mod/devicetable-offsets.h
HOSTCC scripts/mod/file2alias.o
CALL scripts/checksyscalls.sh
HOSTLD scripts/mod/modpost
CHK include/generated/compile.h
PASYMS arch/x86/realmode/rm/pasyms.h
LDS arch/x86/realmode/rm/realmode.lds
LD arch/x86/realmode/rm/realmode.elf
RELOCS arch/x86/realmode/rm/realmode.relocs
OBJCOPY arch/x86/realmode/rm/realmode.bin
VDSOSYM arch/x86/vdso/vdso32-sysenter-syms.lds
VDSOSYM arch/x86/vdso/vdso32-int80-syms.lds
AS arch/x86/realmode/rmpiggy.o
VDSOSYM arch/x86/vdso/vdso32-syms.lds
LD arch/x86/vdso/built-in.o
LD arch/x86/realmode/built-in.o
LD arch/x86/built-in.o
WARNING: arch/x86/built-in.o(.text+0x354ae): Section mismatch in reference from the function penwell_arch_setup() to the function .init.text:mfld_calibrate_tsc()
The function penwell_arch_setup() references
the function __init mfld_calibrate_tsc().
This is often because penwell_arch_setup lacks a __init
annotation or the annotation of mfld_calibrate_tsc is wrong.
CC drivers/misc/stm.o
drivers/misc/stm.c: In function 'stm_dev_init':
drivers/misc/stm.c:388:2: warning: format '%x' expects argument of type 'unsigned int', but argument 2 has type 'long unsigned int' [-Wformat=]
pr_info("stm add %x\n", stm->stm_addr);
CC drivers/usb/dwc3/dwc3-device-intel.o
LD drivers/misc/built-in.o
CC [M] drivers/usb/gadget/epautoconf.o
CC drivers/usb/dwc3/debugfs.o
CC drivers/usb/host/xhci-plat.o
In file included from drivers/usb/dwc3/dwc3-device-intel.c:35:0:
drivers/usb/dwc3/gadget.c:3117:5: error: redefinition of 'dwc3_gadget_init'
int dwc3_gadget_init(struct dwc3 *dwc)
In file included from drivers/usb/dwc3/dwc3-device-intel.c:26:0:
drivers/usb/dwc3/core.h:977:19: note: previous definition of 'dwc3_gadget_init' was here
static inline int dwc3_gadget_init(struct dwc3 *dwc)
drivers/usb/dwc3/gadget.c:3237:6: error: redefinition of 'dwc3_gadget_exit'
void dwc3_gadget_exit(struct dwc3 *dwc)
drivers/usb/dwc3/core.h:979:20: note: previous definition of 'dwc3_gadget_exit' was here
static inline void dwc3_gadget_exit(struct dwc3 *dwc)
drivers/usb/dwc3/gadget.c:3262:5: error: redefinition of 'dwc3_gadget_prepare'
int dwc3_gadget_prepare(struct dwc3 *dwc)
drivers/usb/dwc3/core.h:990:19: note: previous definition of 'dwc3_gadget_prepare' was here
static inline int dwc3_gadget_prepare(struct dwc3 *dwc)
drivers/usb/dwc3/gadget.c:3270:6: error: redefinition of 'dwc3_gadget_complete'
void dwc3_gadget_complete(struct dwc3 *dwc)
drivers/usb/dwc3/core.h:995:20: note: previous definition of 'dwc3_gadget_complete' was here
static inline void dwc3_gadget_complete(struct dwc3 *dwc)
drivers/usb/dwc3/gadget.c:3278:5: error: redefinition of 'dwc3_gadget_suspend'
int dwc3_gadget_suspend(struct dwc3 *dwc)
drivers/usb/dwc3/core.h:999:19: note: previous definition of 'dwc3_gadget_suspend' was here
static inline int dwc3_gadget_suspend(struct dwc3 *dwc)
drivers/usb/dwc3/gadget.c:3288:5: error: redefinition of 'dwc3_gadget_resume'
int dwc3_gadget_resume(struct dwc3 *dwc)
drivers/usb/dwc3/core.h:1004:19: note: previous definition of 'dwc3_gadget_resume' was here
static inline int dwc3_gadget_resume(struct dwc3 *dwc)
LD [M] drivers/usb/gadget/libcomposite.o
LD [M] drivers/usb/gadget/usb_f_acm.o
drivers/usb/dwc3/dwc3-device-intel.c: In function 'dwc3_quirks_process_event_buf':
drivers/usb/dwc3/dwc3-device-intel.c:161:6: warning: unused variable 'reg' [-Wunused-variable]
u32 reg;
Carlos_M_Intel
Hi Rob,
Which is the dongle you want to use with the board? Are you sure you are including all the drivers required for it?
You said that when you do not apply the upstream_to_edison.patch you are able to compile without problems, have you tested this image with the dongle? Is it working?
You should be able to use the board and connect devices as host with the USB A port just by moving the switch SW1 in order to point this port.
Charlie
RDenb
Hi Charlie,
I have tried many different WiFi dongles and host devices, and I'm quite sure that is unrelated to the issue.
When using the 3.10.17 + upstream_to_edison.patch + supplied defconfig, I get the failed to initialize libusb -99 error as well. I can see the switch and have of course tried all manner of booting with a device in place, having the switch set, using a decent 12V external supply - these are not the issue, it is a problem with software.
I have flashed Ubilinux onto the board, conncted external 12V supply, set the switch, and connected any dongle I like and they all "just work" - this is not a hardware problem.
I have tried adding many different kernel modules to my kernel build, and none of them enable me to see any USB devices, or even the USB root hub - everything just gives the failed to initialize -99 issue. With the exception of adding the USB dummy hub, but that is by its very nature not going to help me.
What is clear is that patching the kernel with the patch supplied by Intel, that is supposed to support Edison, actually breaks compilation.
There must be a solution to this, Ubilinux creators have found and implemented it, and either I cannot find the solution that they managed to find, or they have written the solution and not shared it.
Rob
Carlos_M_Intel
Hi Rob,
The upstream_to_edison.patch is intended to be used on the Yocto source files and not in the kernel files from http://www.kernel.org/ www.kernel.org. If you want to build your image with the kernel source files you would need to make the kernel files compatible with Yocto and then run the patch you were using.
I suggest you to use the http://www.intel.com/support/edison/sb/CS-035278.htm BSP file for Edison, you will see all the steps for building an image, and then you can enable all the modules you need with the menuconfig or with the defconfig file. This BSP fetch all the source files for the kernel with the required modifications in order to work with Yocto on the Module.
Charlie
Carlos_M_Intel
Hi Rob,
Do you have updates on this? I would like to know if you have started to create your own image with the required changes you need
Charlie
Carlos_M_Intel
Using the "Edimax EW-7811Un 150Mbps 11n Wi-Fi USB Adapter" you can enable the WiFi-USB driver by doing the following:
1. Follow the http://download.intel.com/support/edison/sb/edisonbsp_ug_331188007.pdf Intel® Edison Board Support Package User Guide and stop after step 4 in the 2nd section "Build an Intel® Edison Image using bitbake".
2. Edit the file /meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux/files/defconfig and add this line:
CONFIG_RTL8192CU=y
CONFIG_RTLWIFI=y
3. Edit the file /meta-intel-edison/meta-intel-edison-distro/recipes-core/images/edison-image.bb and add this line:
IMAGE_INSTALL += "linux-firmware-rtl8192cu"
4. Continue from step 5, build the image and flash the board with the new image
5. Startup Edison, plug in the Wi-Fi USB into Edison USB type-A connector and make sure the micro switch pointing to USB type-A connector
6. Login to Edison Linux console and type the command dmesg | tail -30, you should see the following:
[ 130.906664] usb 1-1: new high-speed USB device number 2 using dwc3-host
[ 130.930176] usb 1-1: New USB device found, idVendor=7392, idProduct=7811
[ 130.930207] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 130.930229] usb 1-1: Product: 802.11n WLAN Adapter
[ 130.930247] usb 1-1: Manufacturer: Realtek
[ 130.930265] usb 1-1: SerialNumber: 00e04c000001
[ 130.932641] rtl8192cu: Chip version 0x10
[ 130.999544] rtl8192cu: MAC address: 74:da:38:42:1d:65
[ 130.999572] rtl8192cu: Board Type 0
[ 130.999731] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 130.999884] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
[ 131.000786] ieee80211 phy2: Selected rate control algorithm 'rtl_rc'
[ 131.016639] rtlwifi: wireless switch is on
[ 131.076912] systemd-udevd[451]: renamed network interface wlan1 to wlp0s17u1
7. Configure the network for the new device wlp0s17u1 with ifconfig wlp0s17u1 up
8. Running ifconfig should show:
wlp0s17u1 Link encap:Ethernet HWaddr 74:da:38:42:1d:65
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
iwlist wlp0s17u1 scan should show the available WiFi networks.
Kind regards,
LLern
I've gotten this to compile and I see the new adapter in ifconfig. How does one get this new adapter to connect to a network using wpa_cli? It keeps selecting wlan0 for me.
Carlos_M_Intel
Hi lernerbot,
Have you tried to configure the interface with connman?
Charlie
