Community
cancel
Showing results for
Search instead for
Did you mean:
MClif
USB Micro A or Micro B
Jump to solution
Regarding the Intel Edison Kit for Arduino, NOT the Breakout Board, I have found some information regarding the type if USB cable required for the left two micro USB connectors that has me confused.
Looking at the following
https://software.intel.com/en-us/appendix-connectors-on-the-intel-edison-board https://software.intel.com/en-us/appendix-connectors-on-the-intel-edison-board
it says:
Middle USB port (Micro A type)
Edge port (Micro A Type)
But looking at
http://download.intel.com/support/edison/sb/edison_arduino_hvm_8_26.pdf http://download.intel.com/support/edison/sb/edison_arduino_hvm_8_26.pdf
it indicates: indicates micro Type-B
Question: is micro Type-B correct and the first reference, above, Micro A type, a typo?
Bill
asss
Valued Contributor II
a document with electrical scheme provides correct information: Micro USB Type B.
The first reference has a typo.
BR,
xbolshe
asss
BR,
xbolshe
