Community
cancel
Showing results for
Search instead for
Did you mean:
MItri
USB performance with X1000
Hi everyone,
for a new project we need a CPU with maximum USB Datarate / we need to copy two USB Memory Devices - 8GByte each to an Ethernet interface (GB Ethernet connected to PCIe) in minimum time. Are there any benchmarks available? Has anyone experiance with USB on Galileo? Can anyone do a quick test (copy a big file of 8GB size to /dev/null, measure time) - my gratitude would chace you eternal ;-)
Thanks Marc
Tags (1)
Community Manager
Hi Marc,
Thank you for contacting us. I haven't tested the Galileo's data transfer but we'll be happy to run the test for you. Just to make sure I understand your request correctly, you want to transfer a big file ~8GB from an external USB to /dev/null and measure the time it takes for it to be completed, right?
I'll be waiting for your response.
-Sergio
MItri
Hi Sergio,
yes - you are right. Transfer a big file to /dev/null and measure the time.
Later on the data has to be transfered to the network but I expect that the 100MBit Interface is to slow. At least I have to reach a datarate of about 17 to 20 Mbyte per second. So if we overcome this hurdle in the first step I will get me a Galileo Board and a mPCIe GB Ethernet card and do the further test on my own.
Thanks in advance - Marc
Community Manager
Hi Marc,
I tried to run the test and did several attempts but was unsuccessful. I tried moving both directories and files to the /dev/null folder and each time the result was mv: write error: No space left on device. I did some research on the /dev/null directory and it is in fact not a directory but a file. It was also explained that you can't actually move things to /dev/null. How did you perform this test on different systems, were you successful when moving files to /dev/null?
-Sergio
FTinetti
Honored Contributor I
Intel Corporation wrote:
Hi Marc,
-Sergio
Hi Sergio,
What's the actual program/command you are trying to run?
Fernando.
Community Manager
Hi FGT,
To run the test I used both the mv and cp commands. I tried to move folders and files to /dev/null. The syntax I used was cp folder_or_file_name /dev/null and mv folder_or_file_name /dev/null. The contents were transferred from a USB drive. Have you moved files to /dev/null? If you have information about this, feel free to share it with the community.
-Sergio
FTinetti
Hi Sergio,
Hi FGT,
-Sergio9
I've only used /dev/null to discard command output (usually verbosity and/or uneeded terminal output). Thus, I've never used cp or mv to /dev/null (it does not make practical sense, except for cases as the one requested by Marc).
I've tested in Galileo, and it is possible only to cp single files to /dev/null, I'll send my experiments as a reply to Marc, just in case they are useful.
Fernando.
FTinetti
Hi Marc,
My experiment: I think a 1.4 GByte file could provide a "good" insight in USB read performance, so I used a 4.0GB USB thumbdrive (actually, the one I had at hand...), connected to an USB OTG via the Intel Galileo USB host (where it's recognized as /dev/sda).
root@galileo:~# cd /mnt/
root@galileo:/mnt# mkdir usbdrive
root@galileo:/mnt# mount /dev/sda usbdrive/
root@galileo:/mnt# ls -lh usbdrive/
total 1.4G
-rwxr-xr-x 1 root root 1.4G Jun 1 2016 file.bin
root@galileo:/mnt# date; cp usbdrive/file.bin /dev/null; date; umount /dev/sda; date
Thu May 12 15:13:25 UTC 2016
Thu May 12 15:15:06 UTC 2016
i.e. about 1.4GB in about 101 seconds.
HTH,
Fernando.
MItri
Hi Sergio, hi Fernando,
sorry - the community server was not reachable for me yesterday -so my answer is late. The command we used in the end is:
dd if=/dev/sda of=/dev/null bs=512 count=204800
14MByte/sec is in the range I have expected - so I think now is up to me to get me a Galileo and do the further test.
Many Thanks to you - Marc
Community Manager
@Fernando-Thanks again for all your help and remaining involved in the community!
@Marc-Thank you for confirming you got the information you needed. Feel free to ask again in case you need further assistance.
-Sergio
