Intel® Makers
9882 Discussions
Ubilinux Edison I2c swapper/1 Tainted
htanw
We are facing this issue . We are using Ubilux and Edison.
Here is our python script is doing
from smbus import SMBus
self.turret_adr = 10
self.i2c = SMBus(6)
and in loop
self.i2c.write_byte(10, 4)
self.ir_reading = self.i2c.read_byte(10)
self.i2c.write_byte(10,5)
x= self.i2c.read_byte(10)
Few times we do get following error after this python script has run for 10 minutes. And many time same script runs for 30 minutes without any issue.
Why randomly after some time we get following error .
Some folks told that we need to configure i2c6 ( like in this link ) But how do I do this in "Ubilinux". There is no such folder "/sys/kernel/debug/gpio_debug/gpio27/current_pinmux" in Ubilinux ?
Till i2c6 works fine, I see following..
sudo i2cdetect -y -r 6
0 1 2 3 4 5 6 7 8 9 a b c d e f00: -- -- -- -- -- -- -- 0a -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
When Error happens, I see following and it never recover from this.
00: [ 2808.569600] i2c-designware-pci 0000:00:09.1: ===== REGISTER DUMP (i2c) =====
[ 2808.569699] i2c-designware-pci 0000:00:09.1: DW_IC_CON: 0x65
[ 2808.569774] i2c-designware-pci 0000:00:09.1: DW_IC_TAR: 0x3
[ 2808.569846] i2c-designware-pci 0000:00:09.1: DW_IC_SS_SCL_HCNT: 0x2f8
[ 2808.569919] i2c-designware-pci 0000:00:09.1: DW_IC_SS_SCL_LCNT: 0x37b
[ 2808.569991] i2c-designware-pci 0000:00:09.1: DW_IC_FS_SCL_HCNT: 0x87
[ 2808.570063] i2c-designware-pci 0000:00:09.1: DW_IC_FS_SCL_LCNT: 0x10a
[ 2808.570135] i2c-designware-pci 0000:00:09.1: DW_IC_INTR_STAT: 0x0
[ 2808.570207] i2c-designware-pci 0000:00:09.1: DW_IC_INTR_MASK: 0x246
[ 2808.570279] i2c-designware-pci 0000:00:09.1: DW_IC_RAW_INTR_STAT: 0x10
[ 2808.570351] i2c-designware-pci 0000:00:09.1: DW_IC_RX_TL: 0x20
[ 2808.570423] i2c-designware-pci 0000:00:09.1: DW_IC_TX_TL: 0x20
[ 2808.570494] i2c-designware-pci 0000:00:09.1: DW_IC_ENABLE: 0x1
[ 2808.570565] i2c-designware-pci 0000:00:09.1: DW_IC_STATUS: 0x2
[ 2808.570636] i2c-designware-pci 0000:00:09.1: DW_IC_TXFLR: 0x1
[ 2808.570707] i2c-designware-pci 0000:00:09.1: DW_IC_RXFLR: 0x0
[ 2808.570778] i2c-designware-pci 0000:00:09.1: DW_IC_TX_ABRT_SOURCE: 0x0
[ 2808.570849] i2c-designware-pci 0000:00:09.1: DW_IC_DATA_CMD: 0x0
[ 2808.570919] i2c-designware-pci 0000:00:09.1: ===============================
[ 2808.571022] CPU: 0 PID: 7312 Comm: i2cdetect Tainted: G W O 3.10.17-poky-edison+ # 1
[ 2808.571027] Hardware name: Intel Corporation Merrifield/BODEGA BAY, BIOS 466 2014.06.23:19.20.05
[ 2808.571035] task: f4f44850 ti: f4dce000 task.ti: f4dce000
[ 2808.571096] Stack:
[ 2808.571164] Call Trace:
[ 2808.571582] Code: b3 ff ff 89 f8 09 d0 80 ce 04 83 ff 02 0f 44 c2 8b 15 54 ab b0 c1 89 82 00 b3 ff ff f7 c6 00 02 00 00 74 14 e8 67 f7 0a 00 56 9d <83> c4 04 5b 5e 5f 5d c3 90 8d 74 26 00 56 9d e8 51 f3 0a 00 83
[ 2808.571607] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G W O 3.10.17-poky-edison+ # 1
[ 2808.571612] Hardware name: Intel Corporation Merrifield/BODEGA BAY, BIOS 466 2014.06.23:19.20.05
[ 2808.571621] task: f6c83d30 ti: f6e1c000 task.ti: f6e1c000
[ 2808.571682] Stack:
[ 2808.571750] Call Trace:
[ 2808.571956] Code: 8b 42 08 a8 08 75 24 31 c9 8d 42 08 89 ca 0f 01 c8 0f ae f0 89 f6 89 e0 25 00 e0 ff ff 8b 40 08 a8 08 75 07 b1 01 89 f0 0f 01 c9 <85> 1d 58 fd b3 c1 75 0d 8d 55 f0 b8 05 00 00 00 e8 8d 34 d9 ff
[ 2808.572591] i2c-6: recovery ignore
Broadcast message from systemd-journald@soosang (Sun 2015-05-31 13:07:17 UTC):
kernel[196]: [ 2808.571022] CPU: 0 PID: 7312 Comm: i2cdetect Tainted: G W O 3.10.17-poky-edison+ # 1
kernel[196]: [ 2808.571027] Hardware name: Intel Corporation Merrifield/BODEGA BAY, BIOS 466 2014.06.23:19.20.05
kernel[196]: [ 2808.571035] task: f4f44850 ti: f4dce000 task.ti: f4dce000
kernel[196]: [ 2808.571096] Stack:
kernel[196]: [ 2808.571164] Call Trace:
kernel[196]: [ 2808.571582] Code: b3 ff ff 89 f8 09 d0 80 ce 04 83 ff 02 0f 44 c2 8b 15 54 ab b0 c1 89 82 00 b3 ff ff f7 c6 00 02 00 00 74 14 e8 67 f7 0a 00 56 9d <83> c4 04 5b 5e 5f 5d c3 90 8d 74 26 00 56 9d e8 51 f3 0a 00 83
kernel[196]: [ 2808.571607] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G W O 3.10.17-poky-edison+ # 1
Sergio_A_Intel
This error has been reported before with the Yocto image. Take a look at this thread . The solution is to move the jumper on J9 to position 2-3. By default this jumper is set to position 1-2.
Additionally, you can post your question in the Ubilinux forum http://www.emutexlabs.com/forum/index EmutexLabs . They are the ones who support this image, so you might get a more accurate suggestion there.
Sergio
