What is the best way to integrate Ublox Neo-6M Gy-gps6mv2 GPS Module to EDISON?
Any lib, exemple, etc?
Hi ROBBIOT,
There's not a specific guide on how to use or integrate this Ublox GPS module with the Edison, however there are various links and guides for other GPS modules that you can use as example. Flo1991 already provided a good thread from the Community and I would suggest you to check these two links http://www.instructables.com/id/GPS-car-tracker-with-Intel-Edison/ http://www.instructables.com/id/GPS-car-tracker-with-Intel-Edison/ and http://www.instructables.com/id/Use-of-GPS-and-Hall-sensor-with-the-Edison/ http://www.instructables.com/id/Use-of-GPS-and-Hall-sensor-with-the-Edison/.
-Pablo
Look at this thread:
gpsd is also a good and easy solution for the ublox module
Flo1991
Hi ROBBIOT,
-Pablo
