Download here
(1) Current Kernel is 4.8RC4 Mainline supporting the following:-
Wireless, External SD-Card, Internal MMC, SPI/I2C
(2) Working-in-progress (streamline):-
SPI/DMA, PWM and intel_idle
(3) Not-yet-started/Unknown:-
No Audio, no BT, no PSH - Platform Service Hub aka Quark MCU, SST - Smart Sound Technology for now
(5) Mainline support with device-tree will officially begin from Kernel 4.9
(6) Login as root/password
Please edit /etc/network/interfaces and include your ssid and password within double quotes.
wpa-ssid "ssid"
wpa-psk "password"
Ap mode is also supported for Ubuntu
(7) Credits to Andy Shevchenko for all the current and future work. His handle in lntel communities is 0andriy
https://github.com/andy-shev/linux/ https://github.com/andy-shev/linux/
Great job getting Ubuntu to run on the Edison!
I am currently trying to get a custom kernel to run on Edison, but I can't seem to get the 8250 serial console to work on any mainline kernels past 4.6.7. I have also tried using Andy's repository with his i386_defconfig and serial still doesn't work. Any ideas?
Also, I have a couple questions related to your Ubuntu 16.0.4 build:
Thanks!
Hi, Thanks for the Ubuntu 16.04.
When I flash this version to MMC memory, I didn't have any problems.
However, when I flashed it to SD card by following AlexT_Intel's instruction.
The problem I encountered was that I couldn't log in using root/password.
When I enter "root", the system returned error without asking password.
Can you figure that out?
Thanks a lot in advance.
Sorry not much time these days MusicIsLife and pilwonhur.
I will try to see if I post all changes, source code, tutorial on how-to make one yourself. I use a customized u-boot. And it should work on external-mmc, whats the error?
