Intel® Makers
9881 Discussions
Unable to Connect Intel Galileo Gen2 to IoT Cloud
NTane
Hi everyone,
I have being trying to connect my board to IoT Analytics dashboard. I have being following the instructions from "https://software.intel.com/en-us/intel-iot-platforms-getting-started-cloud-analytics Intel® IoT Platforms: Getting Started: Cloud Analytics | Intel® Developer Zone" .
The iotkit-agent was already installed but while testing the network using proxy server, i typed the command "iotkit-admin proxy 172.16.1.1 8080", but an error comes that says "set Proxy data".
I tested the command "iotkit-admin test" on my home network too without proxy server, bu an error comes that says
"error: Data Submission Error code=ESRCH errno=ESRCH,syscall=getaddrinfo
error: Connection failed to dashboard.us.enableiot.com"
Does anyone could help me with this issue?
Thanks in anticipation
Nicy
mheo1
Thank for your help. I find that my school's router block my request, so I bring that board home and everything's ok now. Thank you )
Community Manager
First, make sure that you have a connection to the cloud, run the command iotkit-admin test. Check what version you have installed with iotkit-admin –V and notice in https://github.com/enableiot/iotkit-agent https://github.com/enableiot/iotkit-agent that there are several new features related to proxies for different versions. Upgrade if needed following the steps of section 3. Once you've upgraded, try to reset the proxy in case there's a misconfiguration issue with iotkit-admin reset-proxy. Then, try to configure the proxy once again.
Let us know your results.
Sergio
Community Manager
Do you still need help with this thread, were you able to connect to the IoT cloud?
Sergio
NTane
My agent version was 1.7.0 before updating and after updating (using command: npm update -g iotkit-agent), it is same. Do I need to run this command:
iotkit-admin set-data-directory ?
And if yes then how to find the data directory?
I tried to connect my board with my home network, still the error is there.
In my work network I am trying to connect behind proxy server using commands:
1. iotkit-admin proxy http://172.16.80.90 http://172.16.80.90 8080
2. iotkit-admin http_proxy=http://172.16.80.90:8080 http://172.16.80.90:8080
3. iotkit-admin http_proxy=http://username:abcdef1234@172.16.80.90:8080 http://username:abcdef1234@172.16.80.90:8080
Please let me know the correct command for connecting behind the proxy.....
Community Manager
According to https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwiDxbeMnLLMAhUM3WMKHUJGCIk... https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwiDxbeMnLLMAhUM3WMKHUJGCIk...
If you are attempting the connection from behind a firewall with a proxy server, add the proxy
server to the iotkit-admin configuration:
iotkit-admin.js proxy http://proxy.company.com http://proxy.company.com 8080
Sergio
mheo1
I have the same problem!!
2016-04-20T16:31:59.922Z - info: Trying to connect to host ...
2016-04-20T16:32:22.821Z - error: Data Submission Error code=ESRCH, errno=ESRCH, syscall=getaddrinfo
2016-04-20T16:32:22.885Z - error: Connection failed to dashboard.us.enableiot.com
I type iotkit-admin –V then it shown that my version was 1.7.0
I though this problem was about my internet connection because I did this on my school lab. But I can't figure it out because I still connected to internet and can run the Web client on Example sketch.
But I found that my computer cannot ping Google.com while still connected to internet.
Community Manager
If you're not able to ping google from your computer you might have a firewall blocking your requests. Make sure you're not being blocked by a firewall and that you have all proxy settings set correctly, as explained in the post above.
Sergio
mheo1
