It is the 16G micro SD card that came with the 570x dev kit.
devcon /hwid * lists 114 devices regardless if the SD card is inserted or not.
The only drives available are C: and U: neither of which are the SD card.
This is using the latest joule iotcore image from intel, which should have resolved issues mounting SD cards larger than 2G.
The boot manager does list the SD card as an option when the SD card is plugged in, however I am booting from internal eMMC memory.
We would like to use the micro SD card as auxiliary storage.
Any help would be appreciated!
Jeff
Hi Jeff,
Thanks for your interest in the Intel® Joule Platform.
Our team is responsible for fully supporting the board with Reference Linux OS (Ostro), I'm afraid that Windows 10 IoT Core is beyond our support scope. We highly recommend you to post this question in the Microsoft forums: https://social.msdn.microsoft.com/Forums/en-US/home?forum=WindowsIoT Msdn forums – Windows IoT, they should be able to provide you with further guidance pertaining this issue.
Our apologies for any inconveniences this may cause.
-Yermi A.
This was answered at
https://social.msdn.microsoft.com/Forums/en-US/25344f45-b15f-45b5-b481-9110798486fd/intel-joule-unab... Intel Joule: Unable to access SD card with IOTCore / powershell
While we do not currently have an ETA we have identified this as a known issue with the current Joule IoT Core BSP. We are currently evaluating a fix and will be including it in an upcoming release.
Chris
