Intel® Makers
9881 Discussions
Unable to build Ref-OS-IOT
MIzen
Hello
I followed the instructions here: https://github.com/01org/ref-os-iot/tree/master/meta-ref-os-iot ref-os-iot/meta-ref-os-iot at master · 01org/ref-os-iot · GitHub
Using "source 5xx-init-build-env"
When I try to bitbake full-image I got the following error after about 53%:
Thanks in advanced!
ERROR: realsense-objectrecognition-0.5.1-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-rnLrXIIvEk"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/maor/work/ref-os-iot/build/tmp-glibc/sysroots-uninative/x86_64-linux/usr/bin:/home/maor/work/ref-os-iot/intel-iot-refkit/openembedded-core/scripts:/home/maor/work/ref-os-iot/build/tmp-glibc/work/corei7-64-refos-linux/realsense-objectrecognition/0.5.1-r0/recipe-sysroot-native/usr/bin/x86_64-refos-linux:/home/maor/work/ref-os-iot/build/tmp-glibc/work/corei7-64-refos-linux/realsense-objectrecognition/0.5.1-r0/recipe-sysroot/usr/bin/crossscripts:/home/maor/work/ref-os-iot/build/tmp-glibc/work/corei7-64-refos-linux/realsense-objectrecognition/0.5.1-r0/recipe-sysroot-native/usr/sbin:/home/maor/work/ref-os-iot/build/tmp-glibc/work/corei7-64-refos-linux/realsense-objectrecognition/0.5.1-r0/recipe-sysroot-native/usr/bin:/home/maor/work/ref-os-iot/build/tmp-glibc/work/corei7-64-refos-linux/realsense-objectrecognition/0.5.1-r0/recipe-sysroot-native/sbin:/home/maor/work/ref-os-iot/build/tmp-glibc/work/corei7-64-refos-linux/realsense-objectrecognition/0.5.1-r0/recipe-sysroot-native/bin:/home/maor/work/ref-os-iot/intel-iot-refkit/openembedded-core/scripts:/home/maor/work/ref-os-iot/intel-iot-refkit/bitbake/bin:/home/maor/bin:/home/maor/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/maor"; /usr/bin/env wget -t 2 -T 30 -nv --passive-ftp --no-check-certificate -P /home/maor/work/ref-os-iot/build/downloads ' http://realsense-alm-public.s3.amazonaws.com/apt-repo/pool/xenial/main/libr/librealsense-object-reco...' --progress=dot -v failed with exit code 8, output:
--2017-04-13 15:11:29-- http://realsense-alm-public.s3.amazonaws.com/apt-repo/pool/xenial/main/libr/librealsense-object-reco...
Resolving realsense-alm-public.s3.amazonaws.com (realsense-alm-public.s3.amazonaws.com)... 52.218.48.17
Connecting to realsense-alm-public.s3.amazonaws.com (realsense-alm-public.s3.amazonaws.com)|52.218.48.17|:80... connected.
HTTP request sent, awaiting response... 403 Forbidden
2017-04-13 15:11:30 ERROR 403: Forbidden.
ERROR: realsense-objectrecognition-0.5.1-r0 do_fetch: Fetcher failure for URL: ' http://realsense-alm-public.s3.amazonaws.com/apt-repo/pool/xenial/main/libr/librealsense-object-reco...'. Unable to fetch URL from any source.
ERROR: realsense-objectrecognition-0.5.1-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/maor/work/ref-os-iot/build/tmp-glibc/work/corei7-64-refos-linux/realsense-objectrecognition/0.5.1-r0/temp/log.do_fetch.23448
ERROR: Task (/home/maor/work/ref-os-iot/build/../meta-ref-os-iot/recipes-realsense/realsense-mw/realsense-objectrecognition_0.5.1.bb:do_fetch) failed with exit code '1'
Community Manager
Hi Maor_Izenberg,
Thanks for your interest in the Intel® Joule™ Platform.
I'm sorry to hear that you are having issues building the Ref OS IoT image. Is there any particular reason why you are building this image? Because you can find the latest image on this link: https://download.01.org/ref-os-iot/releases/1703/5xx/ Index of /ref-os-iot/releases/1703/5xx .
After you download this image you can create a bootable device (https://software.intel.com/en-us/node/721472 IoT ), then you can flash the image by following these guides:
- https://software.intel.com/en-us/node/721477 IoT
- https://software.intel.com/en-us/node/721470 IoT
I will be waiting for your reply, have a nice day!
-Jose P.
Community Manager
Hi Maor_Izenberg,
We have just received an update regarding building the Ref OS IoT image, could you be so kind to disable the Realsense layer and try again building the image.
We will be waiting for your results, have a nice day!
-Jose P.
Community Manager
Hi Maor_Izenberg,
Were you able to build the Ref OS IoT image? Please let me know in order to assist you.
We hope you have a nice day!
-Jose P.
MIzen
Hi
Sorry for the late reply.
Disabling the layer did help me - thank you!
However, I still have not checked the image yet. I will update for details
Community Manager
Hi Maor_Izenberg,
I'm glad to know that my advice helped! Please let me know if any questions come up, we will be happy to help.
Have a nice day!
-Jose P.
jwu77
I have the same issue. and pass it by disable realsense-xxxx
[jackwu@jackwu-ubuntu1604]$ git diff 683b1ab
diff --git a/meta-ref-os-iot/classes/refosiot-image.bbclass b/meta-ref-os-iot/classes/refosiot-image.bbclass
index 2aefded..9852538 100644
--- a/meta-ref-os-iot/classes/refosiot-image.bbclass
+++ b/meta-ref-os-iot/classes/refosiot-image.bbclass
@@ -8,18 +8,10 @@ FEATURE_PACKAGES_opencv = "opencv"
FEATURE_PACKAGES_opencl = "packagegroup-opencl"
FEATURE_PACKAGES_realsense = "\
realsense-sdk \
- realsense-persontracking \
- realsense-projectionopt \
- realsense-objectrecognition \
- realsense-slam \
librealsense \
FEATURE_PACKAGES_realsense-dev = "\
realsense-sdk-dev \
- realsense-persontracking-dev \
- realsense-projectionopt-dev \
- realsense-objectrecognition-dev \
- realsense-slam-dev \
librealsense-dev \
librealsense-graphical-examples \
uNimb
im also facing same issue's.
it was not create image file. (.wic)
i get following error
root@pro:~/work/ref-os-iot/devlopment_image$ bitbake full-image
Parsing recipes: 100% |# | Time: 0:01:50
Parsing of 2547 .bb files complete (0 cached, 2547 parsed). 3359 targets, 145 skipped, 0 masked, 0 errors.
WARNING: No bb files matched BBFILE_PATTERN_batman '^/home/root123/work/ref-os-iot/devlopment_image/../meta-ref-os-iot/meta-common/meta-batman/'
WARNING: No bb files matched BBFILE_PATTERN_intel-arduino '^/home/root123/work/ref-os-iot/devlopment_image/../meta-ref-os-iot/meta-common/meta-intel-arduino/'
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.33.1"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "sparky-4"
TARGET_SYS = "x86_64-refos-linux"
MACHINE = "intel-5xx-64"
DISTRO = "ref-os-iot"
DISTRO_VERSION = "1.0+snapshot-20170420"
TUNE_FEATURES = "m64 corei7"
TARGET_FPU = ""
meta
meta-selftest = "HEAD:9f225ef5620f2e47e762b2fd16fa5f8d6f1f60fd"
meta-intel = "HEAD:5153dad2fa695bbb579c03ff795ef649269e8420"
meta-refkit = "HEAD:11c3a736d9e824c85f50653db3ec5adabe47a8ae"
meta-oic = "HEAD:b9ba736871b8f8b741cc9c1d88dda56e63a35091"
meta-iot-web = "HEAD:7960e39f92434ee968fc86e38a98eeffdc5041fa"
meta-gnome
meta-networking
meta-oe
meta-python
meta-xfce = "HEAD:5ecbf9bab404af0de7d0f058d1620f40dae0d2d8"
meta-intel-realsense = "HEAD:d60a3c69e0a9f38bdead72bc39857d891f32585c"
meta-ref-os-iot = "master:c320ccd962953eee52be7584167f10a99ac308ca"
meta-qt5 = "HEAD:81fb771c3f31110e50eebcb004809361fdb28194"
meta-ros = "HEAD:2cd378a1c1702e7b3e4ef3e97e987eb6af7b56e0"
meta-java = "HEAD:a265b31ec7d022be254abdf959360a7624208585"
meta-clang = "HEAD:dc1d9d550a5d33d76a3bc6162739edccbd8bf012"
meta-batman = "HEAD:925ad8343613ca3c4274840b9e18225f5be0d231"
meta-intel-camera = "HEAD:a8c6730c2ca7608646a00b7da5460cbc6a08d902"
meta-intel-arduino
meta-5xx = "master:c320ccd962953eee52be7584167f10a99ac308ca"
NOTE: Fetching uninative binary shim from http://downloads.yoctoproject.org/releases/uninative/1.4/x86_64-nativesdk-libc.tar.bz2;sha256sum=101...
--2017-04-20 19:27:07-- http://download.01.org/ref-os-iot/mirror/source/x86_64-nativesdk-libc.tar.bz2
Resolving download.01.org (download.01.org)... 104.121.232.125, 2600:140f:c000:187::ae6, 2600:140f:c000:181::ae6
Connecting to download.01.org (download.01.org)|104.121.232.125|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
--2017-04-20 19:27:09-- https://download.01.org/
Connecting to download.01.org (download.01.org)|104.121.232.125|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 5279 (5.2K) [text/html]
Saving to: '/home/root123/work/ref-os-iot/devlopment_image/downloads/uninative/101ff8f2580c193488db9e76f9646fb6ed38b65fb76f403acb0e2178ce7127ca/x86_64-nativesdk-libc.tar.bz2'
2017-04-20 19:27:10 (696 MB/s) - '/home/root123/work/ref-os-iot/devlopment_image/downloads/uninative/101ff8f2580c193488db9e76f9646fb6ed38b65fb76f403acb0e2178ce7127ca/x86_64-nativesdk-libc.tar.bz2' saved [5279/5279]
WARNING: Checksum mismatch for local file /home/root123/work/ref-os-iot/devlopment_image/downloads/uninative/101ff8f2580c193488db9e76f9646fb6ed38b65fb76f403acb0e2178ce7127ca/x86_64-nativesdk-libc.tar.bz2
Cleaning and trying again.
WARNING: Renaming /home/root123/work/ref-os-iot/devlopment_image/downloads/uninative/101ff8f2580c193488db9e76f9646fb6ed38b65fb76f403acb0e2178ce7127ca/x86_64-nativesdk-libc.tar.bz2 to /home/root123/work/ref-os-iot/devlopment_image/downloads/uninative/101ff8f2580c193488db9e76f9646fb6ed38b65fb76f403acb0e2178ce7127ca/x86_64-nativesdk-libc.tar.bz2_bad-checksum_a192f2246ebc18cb13e3d0569f959863
ERROR: Checksum failure fetching http://downloads.yoctoproject.org/releases/uninative/1.4/x86_64-nativesdk-libc.tar.bz2;sha256sum=101...
WARNING: Disabling uninative as unable to fetch uninative tarball: Fetcher failure for URL: ' http://downloads.yoctoproject.org/releases/uninative/1.4/x86_64-nativesdk-libc.tar.bz2;sha256sum=101...'. Checksum mismatch!
File: '/home/root123/work/ref-os-iot/devlopment_image/downloads/uninative/101ff8f2580c193488db9e76f9646fb6ed38b65fb76f403acb0e2178ce7127ca/x86_64-nativesdk-libc.tar.bz2' has sha256 checksum 1c064fc2366e9f31d7a8eba8d142b4c2f645834b59c702e4fdc413a730578a16 when 101ff8f2580c193488db9e76f9646fb6ed38b65fb76f403acb0e2178ce7127ca was expected
If this change is expected (e.g. you have upgraded to a new version without updating the checksums) then you can use these lines within the recipe:
SRC_URI[md5sum] = "a192f2246ebc18cb13e3d0569f959863"
SRC_URI[sha256sum] = "1c064fc2366e9f31d7a8eba8d142b4c2f645834b59c702e4fdc413a730578a16"
Otherwise you should retry the download and/or check with upstream to determine if the file has become corrupted or otherwise unexpectedly modified.
WARNING: To build your own uninative loader, please bitbake uninative-tarball and set UNINATIVE_TARBALL appropriately.
Initialising tasks: 100% |# | Time: 0:00:13
NOTE: Executing SetScene Tasks
NOTE: Executing Run...
Community Manager
Hi guys,
Thanks for your interest in the Intel® Realsense™ Platform.
happy_jack, you said: "I have the same issue. and pass it by disable realsense-xxxx", are you just sharing your experience, or do you have any more questions?
Umesh@pro3, have you try disabling the Realsense layer?
We will be waiting for your reply, have a nice day!
-Jose P.
uNimb
thanx...... jose P
i didn't tried by disabling this layer,can u tell me more that how i can disable that layer.
step by step
im facing the same fetching error for sensor layers also.
to disable it what changes i have to made.
and one more thing
1st time when im fetching from git,after that how i can use local downloaded file to avoid fetching
with bitbake cmd.
Community Manager
Hi Umesh@pro3,
I would encourage you to read the Yocto Project Reference Manual http://www.yoctoproject.org/docs/current/ref-manual/ref-manual.html# var-PACKAGE_EXCLUDE Yocto Project Reference Manual . Please look for the package exclude and remove information.
Also you can find the latest image of the Ref OS IoT at this link: https://github.com/01org/ref-os-iot GitHub - 01org/ref-os-iot: This is the official distribution of the Intel(R) Reference Operating System for the Internet… .
Hope this helps, have a nice day!
-Jose P.
