I run (on my 2017 macbookpro)
And the result of that is:
21:27 $ ./flashall.sh
Using U-Boot target: edison-blankcdc
Now waiting for dfu device 8087:0a99
Please plug and reboot the board
dfu-util: Device has DFU interface, but has no DFU functional descriptor
Flashing IFWI
Flashing U-Boot
Flashing U-Boot Environment
Flashing U-Boot Environment Backup
Rebooting to apply partition changes
Flashing boot partition (kernel)
Flashing rootfs, (it can take up to 5 minutes... Please be patient)
Rebooting
U-boot & Kernel System Flash Success...
Your board needs to reboot to complete the flashing procedure, please do not unplug it for 2 minutes.
But I still can't configure the board, or connect to it over serial.
(I have successfully flashed two others using the same firmware, but this one's got something against me.)
How can I fix this edison on my Mac. The --recovery option is unavailable on mac's (WTF were they thinking...)
Thanks for reaching out.
I'm sorry to hear you are getting this issue with your board. Could you please double check the steps stated here: https://software.intel.com/en-us/getting-started-troubleshooting-edison-for-linux Troubleshooting and Tips under "The setup tool is not detecting my board"? Additionally, I would like to know if you have installed Homebrew, dfu-util, coreutils, and gnu-getopt as it is indicated here: https://software.intel.com/en-us/flashing-firmware-on-your-intel-edison-board-mac-os-x Flashing the OS Image on your Board with Mac* OS X*.
Moreover, in order to set up the serial terminal with a Mac* OS X*, check if both USB ports are recognized in your PC using ls /dev/cu.usb* command. The output should look similar to this one:
- /dev/cu.usbmodem1413 OTG port
- /dev/cu.usbserial-A502LRS6 Serial port
So you can connect to the USB serial device using the terminal screen utility by entering this command: screen /dev/xx.usbserial-XXXXXXXX 115200 –L. Please be sure to use the serial device which contains cu.usbserial. For more details refer to: https://software.intel.com/en-us/setting-up-serial-terminal-on-system-with-mac-os-x Setting up a Serial Terminal with Mac* OS X*.
Hope you find this information useful.
-Yermi A.
I had this issue too, though it is working now. if you can connect through putty I would recommend just logging in and typing "reboot" to properly reset your edison and hitting enter, it doesn't always work but it is worth trying.
I tried that. But I can't connect to the edison:
08:55 $ ls /dev/cu*
cu.Bluetooth-Incoming-Port cu.lpss-serial2
cu.lpss-serial1 cu.usbmodem1413
08:55 $ screen /dev/cu.usbmodem1413 115200 -L
The terminal window running 'screen' just stays blank with a cursor blinking in the top left corner....
The board also hasn't got WiFi configured, so ssh is out of the question.
P.s. The 'Edison' volume is mounted (and empty), so the Edison has booted up.
-Yermi A.
I have only 1 USB port on my macbook pro....
But I have been able to connect to my board by supplying power from a USB power to the OTB port, and connecting the usb from my mac to the CONSOLE port.
After connecting, I was able to run do_ota in boot mode and use configure-edison --setup to set it all up.
It would have saved me a lot of time if it was explained why I should hook up a USB cable which each port.....
Thnx, I now have all three Edisons up & running !!
