Intel® Makers
9868 Discussions
Unable to flash edison
APovi
condition: Will not boot, will not mount as USB Drive.
Then I tried the flash tool. it completes, however the device shows the following:
software suggests:
Edison board needs to reboot
Please do not unplug it for 2 minutes
On Arduino board, led will stop blinking at boot completed
However it does not blink at all, only the ds1 is illuminated.
if I reset the device eventually I get errors like:
Starting kernel ...
[ 0.757540] pca953x 1-0020: failed reading register
[ 1.602497] snd_soc_sst_platform: Enter:sst_soc_probe
[ 2.006439] pmic_ccsm pmic_ccsm: Error reading battery profile from battid frmwrk
[ 2.024565] pmic_ccsm pmic_ccsm: Battery Over heat exception
or something about panic
Starting kernel ...
[ 0.757241] pca953x 1-0020: failed reading register
[ 1.602552] snd_soc_sst_platform: Enter:sst_soc_probe
[ 2.006387] pmic_ccsm pmic_ccsm: Error reading battery profile from battid fr mwrk
[ 2.024584] pmic_ccsm pmic_ccsm: Battery Over heat exception
[ 2.115810] Kernel panic - not syncing: No init found. Try passing init= opt ion to kernel. See Linux Documentation/init.txt for guidance.
[ 2.115936] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.17-poky-edison+ # 1
[ 2.115999] Hardware name: Intel Corporation Merrifield/BODEGA BAY, BIOS 542 2015.01.21:18.19.48
[ 2.116070] 00016fa6 c1bf3700 f6c89f84 c18d9eea f6c89f9c c18d7de4 00000088 c 1bf3700
[ 2.116186] 00016fa6 00000000 f6c89fac c18cb024 c1ac9678 f6c8bf88 f6c88000 c 18e4bf7
[ 2.116298] c18caed0 00000000 00000000 00000000 00000000 00000000 00000000 0 000007b
[ 2.116409] Call Trace:
[ 2.116464] [] dump_stack+0x16/0x18
[ 2.116518] [] panic+0x81/0x178
[ 2.116572] [] kernel_init+0x154/0x160
[ 2.116627] [] ret_from_kernel_thread+0x1b/0x28
[ 2.116685] [] ? rest_init+0x80/0x80
[ 2.116800] emmc_ipanic: panic notified
[ 2.116839] emmc_ipanic: Crash partition in use!
Please help.
Additional Information and logs.
Flash tool lite output:
11/24/15 22:20:59.596 INFO : [Port -1] Starting flash ...
11/24/15 22:20:59.596 INFO : [Port -1] Running `Notify` command
11/24/15 22:20:59.678 INFO : Displaying notification during 42000 ms
11/24/15 22:20:59.680 INFO : [Port -1] Command `Notify` succeed
11/24/15 22:20:59.680 INFO : [Port -1] Running `Wait for device with status dnx_fw on port -1` command
11/24/15 22:21:08.883 INFO : [Port 1/3] Command `Wait for device with status dnx_fw on port -1` succeed
11/24/15 22:21:08.883 INFO : [Port 1/3] Running `Notify` command
11/24/15 22:21:09.109 INFO : Displaying notification during 5000 ms
11/24/15 22:21:09.129 INFO : [Port 1/3] Command `Notify` succeed
11/24/15 22:21:09.129 INFO : [Port 1/3] Running `"xfstkFlashTool.exe" "-1" "C:\Users\povil\Downloads\edison-image-ww25.5-15\edison_dnx_fwr.bin" "C:\Users\povil\Downloads\edison-image-ww25.5-15\edison_ifwi-dbg-00.bin" "C:\Users\povil\Downloads\edison-image-ww25.5-15\edison_dnx_osr.bin" "C:\Users\povil\Downloads\edison-image-ww25.5-15\u-boot-edison.img" "0x80000007" "none" "none" "0"` command
11/24/15 22:21:09.188 INFO : [Port 1/3] Disabling xFSTK Misc DnX
11/24/15 22:21:09.188 INFO : [Port 1/3] Disabling xFSTK wipe out ifwi option
11/24/15 22:21:09.188 INFO : [Port 1/3] Using xFSTK Solo interface (new API)
11/24/15 22:21:09.188 INFO : [Port 1/3] xFSTK Soft Fuse not set
11/24/15 22:21:09.188 INFO : [Port 1/3] XFSTK Downloader API 1.8.1
11/24/15 22:21:09.188 INFO : [Port 1/3] Copyright (c) 2015 Intel Corporation
11/24/15 22:21:09.188 INFO : [Port 1/3] fwdnx -- C:\Users\povil\Downloads\edison-image-ww25.5-15\edison_dnx_fwr.bin
11/24/15 22:21:09.188 INFO : [Port 1/3] fwimage -- C:\Users\povil\Downloads\edison-image-ww25.5-15\edison_ifwi-dbg-00.bin
11/24/15 22:21:09.188 INFO : [Port 1/3] osdnx -- C:\Users\povil\Downloads\edison-image-ww25.5-15\edison_dnx_osr.bin
11/24/15 22:21:09.188 INFO : [Port 1/3] osimage -- C:\Users\povil\Downloads\edison-image-ww25.5-15\u-boot-edison.img
11/24/15 22:21:09.188 INFO : [Port 1/3] gpflags -- 0x80000007
11/24/15 22:21:09.188 INFO : [Port 1/3] softfuse --
11/24/15 22:21:09.188 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 0
11/24/15 22:21:09.188 INFO : [Port 1/3] Qt: Untested Windows version 6.3 detected!
11/24/15 22:21:10.319 INFO : [Port 1/3] ....XFSTK-LOG--virtual bool MerrifieldDownloader::SetDevice(IGenericDevice*)
11/24/15 22:21:10.319 INFO : [Port 1/3] Initiating download...
11/24/15 22:21:10.320 INFO : [Port 1/3] XFSTK-STATUS--FW(Miscdnx) download is in progress ...
11/24/15 22:21:10.321 INFO : [P...
APovi
So I tried and tried again, and finally an old version flashed, the problem was that rootfs would not transfer all the way.. hang up, but the flashing utility see no problem with that.
I am scared to flash the new firmware now.
could it be a broken USB wire?
Sergio_A_Intel
How are you powering the board, are you using an external power supply in J1? To what old version did you flash?
I noticed you received a "Battery Over heat exception" error. Was the Edison or any components heating up during the flash process?
The Flash Tool lite usually takes a while transferring rootfs at around 88% of the flashing process, this is normal. If you need to re flash to a newer version make sure you are using a USB cable that works with the Edison and to power the board correctly. I use a 12V/2.5A power supply in J1 and have never seen any errors.
Sergio
Carlos_M_Intel
Hi Adomas,
Were you able to flash the board with a newer image?
Charlie
