Community
cancel
Showing results for
Search instead for
Did you mean:
MSidd5
Unable to upgrade firmware and yocto
I have followed both procedures auto and manual install but still unable to upgrade the firmware and yocto
for firmware I'm attaching screenshot
Carlos_M_Intel
Hi MASiddiqui,
What is the outcome while trying with the https://software.intel.com/en-us/articles/flash-tool-lite-user-manual Flash Tool Lite? Could you post the error?
This is the first time you try to flash the image?
Have you tried with different cables and ports?
Which expansion board are you using? Try to power the board with a power supply.
Are you able to start a Terminal session? If you do, what is the output of running configure_edison --version and uname -a?
Charlie
MSidd5
I was able to upgrade the firmware using windows but on mac I'm unable to serial
MSidd5
Im getting resource busy error on mac, but on windows putty is working fine is there an issue with terminal or do i need another software to use cmd line
Carlos_M_Intel
Hi MASiddiqui ,
The message you are receiving on Mac could be due to a process that it still running. Try to run ps and check that there aren't processes running related to the tty.usbserial you are using. If there is a process related to the port you will need to stop it by using the kill command.
Charlie
MSidd5
Thnx, i have already rectified the problem.
