Community
cancel
Showing results for
Search instead for
Did you mean:
JJonn
Unable to upload arduino sketches with micro sd
Jump to solution
Hey there,
I put debian on my galileo gen 2. I'm trying to upload the basic blink sketch, but it won't upload. I get timeout and znak errors every time... The odd thing is that I can upload sketches when the sd card isn't in the galileo. Any thoughts?
FTinetti
Honored Contributor I
Hi jheinz,
Even when you can use Debian, it is not suggested by Intel, yocto is.
You can upload sketches when the SD is not used since Galileo by default accepts sketches, it has (a minimal) yocto in firmware to do so.
HTH,
Fernando.
FTinetti
Hi jheinz,
HTH,
Fernando.
Community Manager
Hi jheinz,
As FGT mentioned, the supported image is Yocto.
You can use the Yocto SD image in order to upload Arduino sketches. It can be downloaded from the following link: https://downloadmirror.intel.com/24355/eng/sdcard.1.0.8.tar.bz2
Diego
