Community
cancel
Showing results for
Search instead for
Did you mean:
MSidd5
Unable to upload sketch
I am running Arduino IDE on OS X.
I am having problem with yocto 2.1:
When the Edison board is running yocto 2.1, i am unable to upload sketch through Arduino IDE.
but when the Edison board is running on yocto 2.0, i am able to upload the sketch through Arduino IDE
Pedro_M_Intel
Hello MASiddiqui,
Which Arduino IDE were you using? I just tested the Arduino IDE 1.6.5 with the x86 boards installed from the board manager on OS X 10.11.2 El Capitan and I was able to successfully upload the blink sketch to my board. I'm currently using the latest image found in https://software.intel.com/en-us/iot/hardware/edison/downloads Intel® Edison Downloads.
Have you tried with Arduino IDE 1.6.5?
Peter.
MSidd5
same here
MSidd5
Were you able to flash your board with yocto 2.1 on your mac
MSidd5
Were you able to flash your edison board with yocto 2.1 on your mac? and were you able to see your board in the flash tool window?
I am attaching a screenshot of whats happening to my flash tool as well, I was able to flash it using terminal but not with the flash tool.
Ken_K_Intel
I also use Arduino on Mac OS X El Capitan.
Which PORT do you use ?
I set PORT to cu.usbmodem.xxxxxx
MSidd5
You can see from the image /dev/cu.usbserial.xxxxxxx
So, you are saying that i should change the port cu.usbmodem.xxxxxxxx
