Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9877 Discussions
Unsatisfied recommendations?
CChir1
on running opkg upgrade i am getting unsatisfied recommendations...?
nodejs-dev: unsatisfied recommendation for python-datetime-dev
nodejs-dev: unsatisfied recommendation for python-netclient-dev
nodejs-dev: unsatisfied recommendation for python-shell-dev
nodejs-dev: unsatisfied recommendation for python-multiprocessing-dev
nodejs-dev: unsatisfied recommendation for python-compiler-dev
nodejs-dev: unsatisfied recommendation for python-subprocess-dev
nodejs-dev: unsatisfied recommendation for python-textutils-dev
nodejs-dev: unsatisfied recommendation for python-misc-dev
nodejs-dev: unsatisfied recommendation for python-crypt-dev
connman: unsatisfied recommendation for connman-conf
connman-dev: unsatisfied recommendation for python-netclient-dev
connman-dev: unsatisfied recommendation for dbus-lib-dev
connman-dev: unsatisfied recommendation for python-subprocess-dev
connman-dev: unsatisfied recommendation for python-fcntl-dev
connman-dev: unsatisfied recommendation for python-textutils-dev
e2fsprogs-dev: unsatisfied recommendation for libcomerr-dev
e2fsprogs-dev: unsatisfied recommendation for e2fsprogs-badblocks-dev
e2fsprogs-dev: unsatisfied recommendation for libe2p-dev
e2fsprogs-dev: unsatisfied recommendation for update-alternatives-opkg-dev
e2fsprogs-dev: unsatisfied recommendation for libext2fs-dev
e2fsprogs-dev: unsatisfied recommendation for libss-dev
uclibc-dev: unsatisfied recommendation for uclibc-librt-dev
uclibc-dev: unsatisfied recommendation for uclibc-libpthread-dev
uclibc-dev: unsatisfied recommendation for uclibc-libdl-dev
uclibc-dev: unsatisfied recommendation for uclibc-libcrypt-dev
uclibc-dev: unsatisfied recommendation for uclibc-libm-dev
uclibc-dev: unsatisfied recommendation for uclibc-argp-dev
uclibc-dev: unsatisfied recommendation for uclibc-libutil-dev
uclibc-dev: unsatisfied recommendation for uclibc-thread-db-dev
uclibc-dev: unsatisfied recommendation for uclibc-libresolv-dev
uclibc-dev: unsatisfied recommendation for uclibc-libnsl-dev
uclibc-dev: unsatisfied recommendation for uclibc-backtrace-dev
redis-dev: unsatisfied recommendation for uclibc-libpthread-dev
redis-dev: unsatisfied recommendation for uclibc-libm-dev
redis-dev: unsatisfied recommendation for uclibc-backtrace-dev
is it due some dependency problem?
how can i troubleshoot this problem?
Community Manager
Hello ChiChi,
Thank you for your interest in the Intel® Galileo Gen 2 Board.
This is more a Linux issue than a Galileo issue, but I'll try to explain why you are getting that notification message.
As you suggested, it is a dependency-related issue, the "unsatisfied recommendation" message appears when the package manager encounters a need for a file (or package) that is not installed. So if you need any of the files listed, you should manually and individually install them.
If you have any update or question, don't hesitate to contact us.
Have a nice day.
Andres V.
