Community
cancel
Showing results for
Search instead for
Did you mean:
PMuld2
New Contributor II
Unsure about route configuration
Jump to solution
after setup of a new subnet 192.168.3.0, I have problems getting the Galileo access to the internet.
When t type 'route', I see:
root@galileo:~# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.3.1 0.0.0.0 UG 0 0 0 enp0s20f6
192.168.2.1 192.168.3.1 255.255.255.255 UGH 0 0 0 enp0s20f6
192.168.3.0 * 255.255.255.0 U 0 0 0 enp0s20f6
192.168.3.1 * 255.255.255.255 UH 0 0 0 enp0s20f6
When I type 'ifconfig' I get:
root@galileo:~# ifconfig
enp0s20f6 Link encap:Ethernet HWaddr 98:4F:EE:05:13:94
inet addr:192.168.3.102 Bcast:192.168.3.255 Mask:255.255.255.0
inet6 addr: 2003:62:477e:eb01:9a4f:eeff:fe05:1394/64 Scope:Global
inet6 addr: fe80::9a4f:eeff:fe05:1394/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:259 errors:0 dropped:0 overruns:0 frame:0
TX packets:268 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:28535 (27.8 KiB) TX bytes:35332 (34.5 KiB)
Interrupt:44
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:245 errors:0 dropped:0 overruns:0 frame:0
TX packets:245 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:18426 (17.9 KiB) TX bytes:18426 (17.9 KiB)
Not sure why the routing table still has 192.168.2.1 and how to setup the new subnet.
Community Manager
Hey Poseid - To delete your old route you'd run:
route del -net 192.168.2.1 gw 192.168.3.1 netmask 255.255.255.255
As for your current network issues, what are you having? Can you ping your gateway, if that works can you ping 8.8.8.8 ? If that works try pinging by name?
Cheers,
-Joe
Community Manager
Cheers,
-Joe
Carlos_M_Intel
Hi poseid,
Did you try with Joe's suggestion? Do you have access to Internet now?
Charlie
PMuld2
New Contributor II
Thanks for the help and sorry for the delay in response.
Joe's suggestion works!
But only ping 8.8.8.8 works, not ping google.com:
root@galileo:~# route del -net 192.168.2.1 gw 192.168.3.1 netmask 255.255.255.255
root@galileo:~# ping google.com
^C
root@galileo:~# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
64 bytes from 8.8.8.8: seq=0 ttl=58 time=17.498 ms
64 bytes from 8.8.8.8: seq=1 ttl=58 time=16.824 ms
64 bytes from 8.8.8.8: seq=2 ttl=58 time=16.844 ms
64 bytes from 8.8.8.8: seq=3 ttl=58 time=16.897 ms
PMuld2
New Contributor II
Ok, last step is adding the DNS server with:
connmanctl> services
*AR Wired ethernet_984fee051394_cable
connmanctl>
root@galileo:~# connmanctl config ethernet_984fee051394_cable --nameservers 8.8.8.8 8.8.4.4
(hmm.. connmanctl is it on github? It would be nice to add some features to make it easier to use)
