Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9868 Discussions
Update Firmware Intel Galileo
BWill15
New Contributor II
I tried to update the firmware of my Intel Galileo Gen 2 with the "Intel® Galileo Firmware Updater Tool".
The board has external power supply en is connected via USB.
It gives an error message "Remote command exited with 127" or "Remote command exited with 254".
What did I do wrong?
Sergio_A_Intel
Are you using an SD card while updating the firmware, how are you powering your board? Were you following this guide https://downloadmirror.intel.com/24748/eng/IntelGalileoFirmwareUpdaterUserGuide-1.0.4.pdf https://downloadmirror.intel.com/24748/eng/IntelGalileoFirmwareUpdaterUserGuide-1.0.4.pdf , at what point in this guide did you get that error?
Sergio
BWill15
New Contributor II
I was using the Intel Galileo Board with an external power supply. I wasn't using the SD card. I was following the guide you mentioned.
I got this error when I clicked the "Update Firmware" button.
I tried it several times, reconnecting and turning the Galileo off and on, after 5 times it worked. No idea why.
