Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Updated edison-src
Jump to solution
I know this has been discussed elsewhere, but that thread seems to have died, so I thought I would bring it up here. It looks like the link to the edison-src file got pulled. Any estimates on how long it will take to get the edison-src file for the newest release? I'm working on a project and no since going through all of the work of getting it to run with the previous version (which looks to be way behind yocto's release schedule), if the new version is going to be out soon. (Not complaining, just was hoping I can get an idea of time)
Ryan
Community Manager
Hi ryanstout,
We're aware about this, and we've been working on it. I know it has taken a lot of time, but hopefully the files will be available soon. Unfortunately I don't have an estimate date on when this will happen, so please be patient.
Diego
Community Manager
Hi ryanstout,
Diego
Community Manager
Diego,
Are you able to tell us why the hold up? I'm just trying to decide if I should try to build with the available version or wait a few weeks.
Ryan
Community Manager
Hi ryanstout,
I'm not sure why it's taking so long since I'm not part of the team in charge of building the images. I recommend you to wait a couple of days (few weeks) if your project allows you to wait that time.
If I get any updates on this, I'll post them here.
Diego
AT9
It seems like the sources are actually published as under "http://iotdk.intel.com/src/3.0/edison Sources – GPL/LGPL source files" link (the link didn't change since the original 3.0 release, just the file behind the link got changed).
From the looks of it, that should be the file we're all looking for, but could someone please confirm that?
Community Manager
Hi AlexT_Intel,
I checked the link and indeed, it seems that those are the correct files.
Diego
EFedo2
I am unable to build this version due to an error in libmodbus. Have you had any success?
Community Manager
Hi egorf,
Could you please share the error log?
Diego
EFedo2
Posted it above
AT9
Return code 5 http://xmlsoft.org/XSLT/xsltproc.html means "error in the stylesheet". Which OS are you building it on?
EFedo2
Hi!
I am using Ubuntu 15.10
I am not sure I understand what an error in the stylesheet means though.
AT9
The error essentially means xsltproc has encountered something in the stylesheet it uses in that failing command, which confused it.
It looks like your Ubuntu version is not on the http://www.yoctoproject.org/docs/1.7.3/ref-manual/ref-manual.html# detailed-supported-distros officially supported distros list for Yocto 1.7.3, so such errors may happen. It worked fine for me on 12.04.
Community Manager
Hi egorf,
We were able to build the image with no errors on Ubuntu 14.04.
As AlexT mentioned, the issue might be caused by the Ubuntu version you are using. I recommend you to change the version, and to follow the steps in the README file.
Diego
EFedo2
For some reason I can't find a code tag, or at least make it foldable, sorry.
Here it is:
DEBUG: SITE files ['endian-little', 'bit-32', 'ix86-common', 'common-linux', 'common-glibc', 'i586-linux', 'common']
DEBUG: Executing shell function do_compile
NOTE: make -j 8
make --no-print-directory all-recursive
Making all in src
make[2]: Nothing to be done for 'all'.
Making all in doc
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_read_input_registers.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_read_registers.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_receive_confirmation.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_receive.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_reply_exception.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_reply.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_report_slave_id.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_rtu_get_serial_mode.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_rtu_set_serial_mode.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_rtu_get_rts.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_rtu_set_rts.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_rtu_set_custom_rts.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_rtu_get_rts_delay.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_rtu_set_rts_delay.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_send_raw_request.txt
a2x --doctype manpage --format manpage -alibmodbus_version=3.1.3 /home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_set_bits_from_bytes.txt
a2x: ERROR: "xsltproc" --stringparam callout.graphics 0 --stringparam navig.graphics 0 --stringparam admon.textlabel 1 --stringparam admon.graphics 0 "/etc/asciidoc/docbook-xsl/manpage.xsl" "/home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_set_bits_from_bytes.xml" returned non-zero exit status 5
Makefile:631: recipe for target 'modbus_set_bits_from_bytes.3' failed
make[2]: *** [modbus_set_bits_from_bytes.3] Error 1
make[2]: *** Waiting for unfinished jobs....
a2x: ERROR: "xsltproc" --stringparam callout.graphics 0 --stringparam navig.graphics 0 --stringparam admon.textlabel 1 --stringparam admon.graphics 0 "/etc/asciidoc/docbook-xsl/manpage.xsl" "/home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_rtu_set_serial_mode.xml" returned non-zero exit status 5
Makefile:631: recipe for target 'modbus_rtu_set_serial_mode.3' failed
make[2]: *** [modbus_rtu_set_serial_mode.3] Error 1
a2x: ERROR: "xsltproc" --stringparam callout.graphics 0 --stringparam navig.graphics 0 --stringparam admon.textlabel 1 --stringparam admon.graphics 0 "/etc/asciidoc/docbook-xsl/manpage.xsl" "/home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_rtu_get_rts_delay.xml" returned non-zero exit status 5
Makefile:631: recipe for target 'modbus_rtu_get_rts_delay.3' failed
make[2]: *** [modbus_rtu_get_rts_delay.3] Error 1
a2x: ERROR: "xsltproc" --stringparam callout.graphics 0 --stringparam navig.graphics 0 --stringparam admon.textlabel 1 --stringparam admon.graphics 0 "/etc/asciidoc/docbook-xsl/manpage.xsl" "/home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_send_raw_request.xml" returned non-zero exit status 5
Makefile:631: recipe for target 'modbus_send_raw_request.3' failed
make[2]: *** [modbus_send_raw_request.3] Error 1
a2x: ERROR: "xsltproc" --stringparam callout.graphics 0 --stringparam navig.graphics 0 --stringparam admon.textlabel 1 --stringparam admon.graphics 0 "/etc/asciidoc/docbook-xsl/manpage.xsl" "/home/egor/image-v3.0/iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/libmodbus/3.1.3-r0/libmodbus-3.1.3/doc/modbus_rtu_set_custom_rts.xml" returned non-zero exit status 5
Makefile:631: recipe for target 'modbus_rtu_set_custom_rts.3' failed
make[2]: *** [modbus_rtu_set_custom_rts.3] Error 1
Makefile:488: recipe for target 'all-recursive' failed
make[1]:...
